Use hard drive from virigin and sky box
  • stevo1916
    • Oct 2011
    Hi i was wondering if i could use a hard drive from sky + box and virgin v box? i have a hard drive from both but when i connect them to my pc they are not detected would be good to use them if it is possible
  • chris31560
    • Feb 2010
    • 912
    no m8, u cant use hard drives from vermin or sky on ur comp, they just wont do,,
    A LITTLE THANX GOES A LONG WAY
    • willywonker2010
      • Mar 2010
      • 449
      u can low level format em
      ther is software hirens boot disk
      or find manf disk boot
      from disk
      • Shady
        Shite Link King
        • Dec 2010
        • 6404
        WRONG ON SO MANY LEVELS.....
        I and many others have succesfully used old sky and vermin hdds, even btvision and tiscali ones... they are bog standard hds that can be used in any pc, even with letting windows format them.. im using a 500gb in an externalcaddy right now and guess where i got it from? thats right, sly hd box
        • andy211081
          • 575
          thats good then as i have 2 1tb sky boxes sat under my bed collecting dust !
          Ladies and Gentlemen, this is your captain speaking. I have the only gun on board. Welcome to Con Air.
          • potrobber
            • Mar 2010
            • 493
            they also go into vu duo,s with no problems at all
            • omegauk
              • Aug 2012
              virgin box H Drive
              I have a 500gb hard drive out of a virgin box, but when I connect it to my desktop using external caddy, the computer does not find it, is there a way for it tobe found.
              Thanks for any replies.
              • ozz001
                • Aug 2012
                virgin hd's
                yep hd's from virgin box are fine to use. good drives..
                you just need to format the with half decent software. software on hirens will be fine..
                • 56kevins
                  • Apr 2012
                  • 7
                  You have to reformat it. If you have w7 or vista go to disc management, delete the volume then create a new simple volume then quick format it using ntfs file system.
