Password bios dell latitude e6320
  • dellhacks
    • Feb 2013
    dell latudude E6320
    bios reset can only be done with open the case
    remove all screws under de laptop flip it over.
    remove plastic square arond keybord.
    remove all the screws under the keybord.
    remove the cover .
    if you are done with that you wil see in the left
    corner the flatcable from hd remove that.
    there is an bios chip located most be an atmel 11131
    8 legs. little right and up from the flatcable!!!!!!!!!!!!
    from the hole on de cmos count leg 3 shotcut with leg 6.
    start laptop and tap the wires solder 2 wires 1 on leg 3 and leg 6.
    if laptop starts up tap the wires to eachother.
    if yo still see the password asking don't worry
    remove the wires and solder leg 4 end 8 do the same .
    if that also dont work last option soler leg 3 and 7 and do the same.
    1 of this solutions will work!!!!!!!!!!!!!!.
    don't belive bullshit story's about cmos battery remove.
    this is nonsens.
    take care and post an replay if everyting is fixed .
    • PwdForDell
      • Apr 2013
      • 11
      #17
      Sorry all infos above is totaly wrong if you follow that you will end with a dead motherboard! can't imagine guys posting this.
      • dave11674
        • 2025
        #18
        any more news on this laptop ??
        can the hdd and bios passy be removed ?
        if so how is it done ?
        also the reply by dellhacks...
        this has worked on other laptops for me in the past.
        not sure what bios chip is in this dell tho
        dave
        Tools owned.
        AVDI commander.
        Dashfixer orig.
        Dashfixer clone.
        Fiat km tool.
        Opel km tool.
        Ford KM tool.
        Op--com colne.
        Lexia & PP clone.
        Smok PSA, volvo & ford
        If someone helps you DONT FORGET TO SAY THANKS its only polite....
