pc shuts down without warning
  • jckw
    • 760
    #16
    Originally posted by cunny
    Just make sure everything is clean and free of dust once reseated with enough paste, it should be fine
    will do m8 thanks
    we are all learning each day
    • camelv
      • 1202
      #17
      mine done the same a couple of years back m8 opened it up and it was caked in dust , i give it a good clean out and fitted an additional fan ,its been ok ever since m8.
      its the stuff we think we know that stops us all from learning
      • cunny
        • 4915
        #18
        how is the machine now?
        • jckw
          • 760
          #19
          hiya lads pc still shuts down re applied paste to cpu and cleaned it all out its still shutting down without warning help please
          • cunny
            • 4915
            #20
            Does it just go dead? Will it turn back on straight away?
              Did you try removing the ram and trying each stick in turn ?
              • jckw
                • 760
                #22
                i can turn it back on but it turns its self off after a short while each time i try it lasts less time before it goes off
                • jckw
                  • 760
                  #23
                  yes m8 tryed taking ram out still the same could it b power supply unit
                  • dj flame
                    • 27
                    #24
                    Ok pal, if you have tried the ram and applied new paste (did you get a better cooler?)
                    Have you overclocked it in any whaY or added any new bits that may require more juice?
                    If so then I would go for a better PSU but make sure you get a decent modle as a shite one could ~~~~ everything up.
                    I'd get one of these as they are stable as you like
                    ELT500AWT-ECO - 500W Enermax LibertyECO PSU, 86% Efficiency, 2x PCI-E 6+2P, 5xSATA, 2x12V 38A, PeakPower 550W - Scan.co.uk
                    thats what I have
                    cheers
                    • jckw
                      • 760
                      #25
                      thats what I have
                      cheers
                      thanks m8 will try this one
                      • jckw
                        • 760
                        #26
                        pc goin to the shop aghhhh
                        pc still shutting down tried new ram new paste to cpu and a third fan and this bastard is still shutting down when its been on for a while any pc engineers out there help please
                        • jckw
                          • 760
                          #27
                          chroma help me please
                          • grizzlyt
                            • Oct 2008
                            • 93
                            #28
                            It could be that your Pram battery is empty, then there can be a lot of problems.
                            On your motherboard, remove the battery and change it for a new one.
                            Try to find the red button to make a reset with a paper clip before replacing it.
                            I hope you can find the problem, sometimes the solution is in front of you.
                            IP Box HD 9000 2xS2 tuner
                            Dreambox 7025-SS
                            Smart MX 28-IDTE IQ 2040
                            Sammy 9500-Sammy 9400-Sammy 9000
                            Triax 120 cm-Titanium 2 LNB's
                            • cunny
                              • 4915
                              #29
                              Can you list all the hardware in the machine please and the psu
                              • aftermath
                                • 4345
                                #30
                                the heat damage might already goosed your CPU, so no matter how much paste you put on or what fan you use , it wont bring it back to life.
                                Have your motherboard checked out.
                                make sure all boards are securely in their slots.
                                Check all fans are working ( even in your power supply ),
                                memory or video faults should beep when there is an error.
