windows wont boot
  • garethr
    • 16
    #16
    Yeah sure give that a go above. I have used similar tools and although they are usually pretty good, they arent 100% reliable and a few faulty HDDs have slipped the net. Its worth a go though. The more diagnostics you perform the closer you will get to your solution
    • Hoppy01
      • May 2011
      • 374
      #17
      Originally posted by paddybongo
      Hi all i just finished helping a friend with his Toshiba Satellite W7 LAPTOP.formatted the drive a installed new windows,because it would not boot up no matter what,
      every thing going good like new until today when they inserted a game angry birds and the system froze.I'm trying a repair disc but i get as far as the language option and change to united kingdom goes to the next screen and freezes,also iv tried safe mode but goes so far and then just stops.
      im now trieing to boot mini xp but get so far and it says the drive is not ready for use,its door may be open.Please check drive/device/harddisk0/dro and make sure that a disk is inserted and the drive door is closed.
      It could be a number of things but a would guess one of your drives is faulty or not seated properly..
      Even if the hard drive is humped it should still boot a live disc from your optical drive..
      Get the back panels off it and make sure all cards and drives are seated properly .
      When you reboot make sure all usb devices are unplugged as a usb pen plugged in can completely cripple Windows at start up..
      Listen for a continues clicking noise from the hard drive and also any horrible clunking noises from the optical drive.
      If still wont boot a live disc after doing this then post back..
      "Windows - A thirty-two bit extension and GUI shell to a sixteen bit patch to an eight bit operating system originally coded for a four bit microprocessor and sold by a two-bit company that can't stand one bit of competition."
      • siddharta
        • Jun 2012
        #18
        linux
        sounds like hard drive mate. quick n easy way to tell - boot a live linux disc (ubuntu, xubuntu etc) and if it boots and loads properly, its the hard drive
        just read the post above me properly....sorry mate, wasn't nicking your ideas!
