System Volume Information
  • gizmo.1484
    • 873
    Can anybody tell me how to find this file as i need to delete as my AV says is a potentially unwanted program.
    C:\System Volume Information\_restore{74606CO5-3178-484C-B2EB-EE522C7A4EF1}\RP156\A0208545.dll
  • caveman_nige
    • Feb 2008
    • 4920
    turn off system restore then scan PC, then switch system restore back on and scan again.. Had to do this myself before...
    • h07kill3r
      • 6
      from folder options in tab view set windows to show hidden and protected operating files and then disable simple file sharing. then right click on the folder "System Volume Information" select sharing and security goto tab security, click add and type everyone and in permitions select all... then goto "C:\System Volume Information\_restore{74606CO5-3178-484C-B2EB-EE522C7A4EF1}\RP156\" and delete the file A0208545.dll
      • gizmo.1484
        • 873
        Cheers for that mate i will give it a try.
        • Messa
          • 41
          This is the best and easiest edvice, trying to delete it manually might be a problem unless you disable the restore service in services.msc anyway.
          Once you disable restore the files are removed anyway.
          Just then reboot and enable again.
          Messa
