motherboard
  • sandy
    • 16
    motherboard
    using a m4a89td pro series
    bought 32 gig of ram for it
    but it only reconises 16 gig of it
    runing windows 7 32 bit
    any ideas how to get full 32 gig reconised
  • ray156
    • 669
    as far as i know windows 7 32bit will only work with up to 4gb ram,any more than that is just a waste,i could be wrong,
    but just like xp,can put in 8gb ram but it will only work with a max of 3gb.
    But this is not the case for the 64-bit flavor of Windows 7. The Home Basic and Starter SKUs can manage up to 8 GB of RAM, with Home Premium taking the limit to 16 GB. The Professional, Enterprise and Ultimate versions of Windows 7 will support as much as 192 GB of RAM.
    • cunny
      • 4915
      As ray said could be windows version
      Max memory limits for 64-bit Windows 7 | ZDNet
      However, also check to see if a bios update is required
      • sandy
        • 16
        its reconising 16 gig
        how do i check if bios needs updating
        • Shady
          Shite Link King
          • Dec 2010
          • 6404
          check date of biso revision, go to manufacturer website download latest date. website prob have a checking tool on there
          • sandy
            • 16
            cheers will give it a go
            now if i have to buy a new windows os am i better going for 64 or 86
            • cunny
              • 4915
              Did you not read rays reply? If you want to use 32gb of ram then you will need a x64 os. However read the link i posted as not all window7 versions will see upto 32gb of ram.
              • Canker_Canison
                • 3904
                My understanding on this is a little different to whats above.
                Yes you will need to switch to Windows 7 x64
                But as it is, windows will see it, but will only let you use 8GB. The other 8GB will be used for paging instead of the HDD.
                Canker
                [COLOR=Green]
                • sandy
                  • 16
                  cheers for the heads up guys and galswill be buying w7 64 ultimate
                  • Shady
                    Shite Link King
                    • Dec 2010
                    • 6404
                    BUYING?
                    • ray156
                      • 669
                      BUYING?
                      @ buying
                      l.m.a.o.
                      • sandy
                        • 16
                        instaled w7 64 ultimate
                        runing fine
                        had to put in a new cpu cooler
                        and unfortunatly its massive so i had to take 2 sticks of memory out
                        major bummer
                        still pc is working fine with 16 gig ram
                        ps for the record
                        when i was runing w7 32 bit
                        it reconised 16 gig ram also
                        many many thanx for your help guys its apreciated
                        • knot7
                          • Jun 2012
                          Maybe because that mother board only recognizes 16gb of ram? daaaaa!!
