pc overheating and freezing pls help
  • ozmastero
    • 152
    Continuing from: http://www.digital-kaos.co.uk/forums...ashing-273385/
    i finally installed windows 7 on my gaming pc and after a week it has started to freeze.
    I then found out its due to over heating.
    So now it freezes all the time. i cleaned fans dust etc etc no clue why it would all the sudden heat up so much
    any help please
  • Cod3waX
    • 1011
    so is the processor over heating?
    u need to take off the heatsink clean that up then clean the cpu add new paste and re-assmble
    to remove old heatsink paste if theres any left use alcoholic cleaing solution or wipes even baby wipes n cotton buds
    • rg66
      • Dec 2011
      • 133
      Are you sure it's over heating? These days most comps shut down so it doesn't fry the CPU.
      If it is over heating, can you hear the fan running at all?
      • Canker_Canison
        • May 2010
        • 3904
        My favorite is DAE Brake & Carb cleaner. A squirt of the cleaner & a couple of wipes & it's just like new.
        Gotta be careful around some paints & plastics... it does like to melt them. Especially on Xbox's
        Canker
        [COLOR=Green]
        • ozmastero
          • 152
          The fans are both on and yes it just seems to overheat.
          What paste must i put on?? weird how its doing that though it freezes to avoid overheating the cpu
          • ozmastero
            • 152
              Silver thermal paste m8.............
              check link...............
              silver thermal paste | eBay
              • ozmastero
                • 152
                I took paste off now where can i buy new one pls anyone??
                  Check the link m8 its flebay and y did you take the paste off its there for a reason to STOP it overheating.................
                  • ozmastero
                    • 152
                    Read above people said to take it off
                    i bought the third one down hope its good it came to like 4.75
                    so you think putting this on will solve it??
                    • DOUGALMCD
                      • May 2011
                      • 3229
                      You'll only know when you try and that's if you've done it right.
                        No it dont its says take heat sink off and clean reassemble with new paste dont no about solving it but it will definitely help...................
                        • ozmastero
                          • 152
                          Well i took it off is that bad??
                          and how do i put it on the right way please??
                          Is there anything else i can do? thanks
                          • DOUGALMCD
                            • May 2011
                            • 3229
                            Apply a thin film evenly and reassemble.
                            • Cod3waX
                              • 1011
                              read this osma it will help Thermal Paste and How To Use It
