i'm using toshiba satellite laptop with mains power only as the battery overheated, over the last few days if i move the laptop say a foot or so it switches off and i have to reboot i can only move it very gently and slowly but sometimes it still loses power and sometimes it takes 3-5 clicks of the power button to switch on again is the problem just the power lead needs replacing? i've checked to make sure its plugged into the wall firmly and the connection to the battery charger and the connection to the laptop are all in properly. any ideas?
laptop loses power when i move it
Tags: None
Could be one of many problems, dodgy power supply, messed up charger port, loose connection inside or just a ~~~~ed up laptop, my money is on power supply. I would replace the whole charger as they usually come in two parts which connect together. Might not be a bad idea to call up a few local computer shops to find out if they have a power supply for your laptop, so you can try before you buy
could also be a dodgy dc jackFave replies from various threads
as shady said,its the dc jack.on the laptop,
the dc jack only has a small tin lip on negative side of jack,
everytime you move laptop,you are bending that lip back into slot on jack,eventualy you wont be able to connect with it at all.
the people i have told,dont move laptop while cable in back,
but do they listen,NOT.
good for me,as i have replaced the same laptop 4 times with dc jacks,money in my pocket.
i love peeps that do it.
but to replace is murder,its a full laptop strip down,motherboard out.Comment
well you could have said fud that you repair these things
. daughter had same thing happen a while back.. clever me decided to sort it.. did the bizzo.. result.. one sale of broken lappy on fleabay
LMFAO....yep that can happen.easy to do,just all the stripping laptop down thats the problem,some laptops got to even take heatsink from cpu to get into.
supply and fit dc jack local pc shop ? 80
local diy guy-me.. ? 25Last edited by ray156; 28 June, 2012, 13:35.Comment
can i refit the battery?
can i re-fit the battery after it reheated? i've got firefox with windows 7,even when i had the battery fitted i always kept it plugged into the mains as it worked faster that way.as shady said,its the dc jack.on the laptop,
put battery back in,charge it,NOTE battery will get warm while charging,run laptop on battery only,time how long it lasts,to check if battery a gonner.a good battery should last 2-4 hours.the laptop will run brighter on mains.Comment
i've now re-fitted the battery and have it plugged into the mains for the battery to charge its about 80% it says 1hr 53 remaining,i thought when i removed it that it had no charge as i couldnt switch on the laptop with it fitted but no problem today? switched on straight away, as i'm sure you can tell i have very little computer knowledge and i dont understand a lot of the terminology.Comment
5 yrs ago i could not work a pc,then i found a couple of old pcs in a skip,took them home,messed about with them,take this out take that out,put this here etc,and got one working.not looked back since,i now build new pcs for friends,i've now re-fitted the battery and have it plugged into the mains for the battery to charge its about 80% it says 1hr 53 remaining,i thought when i removed it that it had no charge as i couldnt switch on the laptop with it fitted but no problem today? switched on straight away, as i'm sure you can tell i have very little computer knowledge and i dont understand a lot of the terminology.Comment
wasn't getting any power to the laptop this week so just back from a local computer shop and thankfully it was the power lead not the jack pin.Comment
