memory checker software ??
  • berley
    • 567
    Can someone advise me of a programme I can use to check the memory on my puter,
    The reason for wanting to check it is im having problems when I download games, when it comes to extracting them I get the following message :-
    The file is either in unknown format or damaged
    I can download and extract films and music no probs but I never get the iso when I download games, its fine on my laptop I can download them no problems and extract the iso, this is only happening on my main pc
    I was advised that this could be due to corrupt memory so before I go and replace it I?d like to check it first, something idiot proof and easy to use would be nice
  • Bobiskey
    • 48
    Memtest86.com - Memory Diagnostic
    Download, burn it to disc, boot from disc, let it run over night if pos. If theres a problem, this will find it.
    .: Bob :.
    He Lives in a pineapple under the sea....
    Sponge Bob Square Pants ...
    • cunny
      • 4915
      What are you using to download, torrents, usenet?
      If i remember this is a fault with quickpar is it not?
      • berley
        • 567
        it doesn't matter if i download from newgroups, torrents or rapid share, i still get the same error message
        i downloaded a game from torrents on my laptop and unrarred it and the ISO Image file was fine
        copied the whole file onto disc and put it on my main pc hard drive and when i opened it i got the error message
        the archive is either in unkown format or damaged
        i use exactly the same software on the laptop as what i have on the main pc
        ive also had ft double check the files i download, he downloads same file from same place and he gets the ISO
        • cunny
          • 4915
          its sounding like a read/write error, replace the cables from the hdd to motherboard.
          • cunny
            • 4915
            Just for you berl
            SATA:
            IDE:
            note on the ide it could be slimmer than the ribbon style, just look at the connections.
            Like these
            • berley
              • 567
              cheerz hun, i prefer piccies
              will try tomoz from an older puter i've got and let you know the outcome
              • cunny
                • 4915
                If not put the hard drive from the old 1 and download to there, but its sounds to me a hard drive fault.
                If you need anymore help shout me
                Sorry forgot to ask piccies of what exactly ???
                • berley
                  • 567
                  hiya cunny soz i didn't get back to you earlier about this, anyhow its sorted now, it was a file association problem
                  i appreciate the piccies and time you took to try and help with this - thanks a million
                  • cunny
                    • 4915
                    Glad its sorted, sounded similar to a problem i had with quickpar what turned out to be the leads, the joys of when your actually sat in front of the thing.
                    Anyways glad its sorted out
