PC help
  • robbbin
    • Aug 2012
    • 27
    PC help
    Hi Have a Advent 4211c getting all sorts of problems will not system restore tried all the obvious, it will not remove some programs to free up space chrome not working can not remove it also getting slower even in safe mode will not system resore only goes back 1 day what is the easiest way to factory reset its a notebook so no disc
    Rob
  • Cod3waX
    • 1011
    try this
    1. When the PC starts you will see a menu for two seconds. Press the UP or DOWN arrow and this will pause the menu and allow you to choose an option.
    2. Highlight The TechGuys Recovery and press the Enter key.
    3. This will load into the recovery program.
    4. Select Reinstall Windows by clicking on the circle to the left.
    5. Click the right arrow.
    6. Put a tick in the box next to Start Full Destructive Recovery.
    7. Click the right arrow to start Recovery.
    8. When Recovery has completed, click the right arrow to restart the system.
    9. Your computer will then return you to its initial out-of-box experience.
    • robbbin
      • Aug 2012
      • 27
      Sorry should of said techguys recovery was wiped from machine is it possible to get it
      • teac532s
        • 28
        Hi. Sounds like you will need to make a bootable usb drive and reinstall from that or a bootable external hard drive with xp or 7 whichever you prefer. Google boot windows from usb. i have done it lots of times its not so bad
        • Cod3waX
          • 1011
          Recommend ya download 1 of these http://www.digital-kaos.co.uk/forums...64-bit-220877/
          then follow the step by step instruction from here to make ur bootable usb How to create a bootable Windows 7 USB flash drive | Ars Technica
          • uniquegeek
            • Oct 2012
            • 45
            Try and Install MALWAREBYTES and run a deep scan
            If your Advent lets you install it, you may be in luck and able to get rid of dodgy scripts running on your computer.
            Once done Try system sretore again
