windows 98 installing problem
  • batandball
    • May 2011
    • 733
    I needed to install window 98 on a pc for a certain software. While installing something gone wrong, keeps asking to clean disk then press ok but still the same. got a different windows disk now. I need pc to boot up off the cd windows 98 disk, how do i do that
    many thanks BatandBall
    If it works use it
    BatandBall
  • Cod3waX
    • 1011
    m8 try installing it using vmware
    what is the program u trying to use ???
    there is compatibility mode in xp vista & 7
    • R_J
      • 492
      Go into the pc system bios and make sure first boot device is cdrom, it should then boot from the cd (if it's a bootable cd)
      • Canker_Canison
        • May 2010
        • 3904
        Also check the format on the HDD. 98 won't work with NTFS. Make sure you format for FAT32
        Canker
        [COLOR=Green]
        • batandball
          • May 2011
          • 733
          SOLVED CHEERS
          If it works use it
          BatandBall
