Hi my Dell insperon n7010 keeps rebooting when I unplug the charger and displaying a era message.dis only start happening when I upgraded to windows 8 pro
windows 8 keeps rebooting when charger is disconnected
Tags: None
battery
Sounds like a battery problem to me, a least that's the first place I'd look. Even new batterys go bad and if not conditioned correctly on day one(first time you turned your laptop on) they may never hold a charge or fail.
In windows 8 the warning about failing battery is turned off by default.Comment
Lads hears what I did but didn't seem to work,
The minidump files showed SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M (1000007e) and ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY (fc) stop errors both appeared to be caused by the atikmdag.sys:
BugCheck 1000007E, {ffffffffc0000005, fffff88004a57b5b, fffff880069c2858, fffff880069c2090}
Probably caused by : atikmdag.sys ( atikmdag+79db5b )
BugCheck FC, {fffff88004dd6460, 87a000010706b121, fffff880069b88f0, 2}
*** WARNING: Unable to verify timestamp for atikmdag.sys
*** ERROR: Module load completed but symbols could not be loaded for atikmdag.sys
Probably caused by : hardware ( atikmdag+9b9460 )
The atikmdag.sys. which is dated Oct 3, 2012, is the AMF display driver.
What you could try is to uninstall the ATI display driver and then reinstall the AMD driver
Minidumps are here.
Minidumps are here.
https://skydrive.live.com/redir?resi...Pdva0wpRQA5Y1Y
Ave always found ATI drivers utter s***, a had a similar problem with a customers machine a few weeks ago.
A found installing a older driver done the trick ..."Windows - A thirty-two bit extension and GUI shell to a sixteen bit patch to an eight bit operating system originally coded for a four bit microprocessor and sold by a two-bit company that can't stand one bit of competition."Comment
