laptop problem
  • boleyn80
    • Feb 2011
    • 43
    laptop problem
    hi guys, i am currently using an -acer aspire 5935g, running windows 7, it seems to be running slower than usual, every 10-15 minutes or so it just stops and says "internet explorer not responding" also on the bottom of the laptop it seems to get quite hot near to where the fan is situated, is there any help or advice on this please, hope to hear from someone soon, cheers.
  • Cod3waX
    • 1011
    4 things to do
    also ho much hdd space is free on the C drive?
    1.click start and type in MSCONFIG then select STARTUP and take the ticks out of any program u dont wont to run on startup (DO NOT take the ticks out of anything using
    C:\windows)
    2.make sure ur windows is upto date Click START and type UPDATE select windows update and check
    3.download ccleaner an clean ur windows Download CCleaner 3.26.1888 - FileHippo.com
    installed selcet CLEANER then ANALYZE then RUN CLEANER
    (if u want internet exploere to save any login id's & passwords then take the tick out of cookies)
    then select REGISTRY and SCAN FOR ISSUES and then FIX ISSUES
    4.if u have a air compressor then use it very gently around ur air vents on ur laptop
    also would like to see what temputures ur hardware is getting
    install the upload and give use the temps of ur cpu and gfx card
    • nibblitz
      • 1300
      Make sure your OS is up to date, check Windows Update and allow all updates..
      Make sure your Laptop has the latest version of Adobe Flash Player installed..
      Run a full Virus & Spyware Scan... Check for Malware using Malwarebytes..
      Do as Cod3wax says and stop any unwanted programs starting automatically, or better still, uninstall any unwanted programs..
      Do not use compressed air on the air vents, all it will do is blow fluff and dust deeper inside the laptop... If the air vents look a bit fluffed up carefully pass the end of your Vac cleaner nozzle across them...
      • wolfsk
        • Jan 2013
        Try to clean the fan and heat sink. I had the same problem and it works fine.
        • XRay333
          • Jul 2012
          • 118
          Reverse air flow
          Use compressed air but use it on the air out vent . this will blow the hair, lint and fuzz right out the intake vent. I've been doing this for years with 100% positive results on more laptops then I can count.
          • Hammerfrog
            • Jan 2013
            Add a vacumcleaner and youll get a shiny new pc
            • boleyn80
              • Feb 2011
              • 43
              thanks very much guys, im gonna get onto it right away, its really doing my head in, ill let u know what happens, thanks again
              • Hoppy01
                • May 2011
                • 374
                Yeh and you might also cripple the PC after sucking bits off the board..
                Back on topic, a would run Ccleaner, do a defrag and update the usual suspects like Java, Flash, Adobe Reader and of course Windows updates.
                Like others said, hit it with a can of air but do not use a hoover..
                "Windows - A thirty-two bit extension and GUI shell to a sixteen bit patch to an eight bit operating system originally coded for a four bit microprocessor and sold by a two-bit company that can't stand one bit of competition."
                • nibblitz
                  • 1300
                  I'll say it again, do not squirt compressed air into a Laptop, its very silly..
                  (But then, as a Qualified HP/Compaq Engineer, what do I know)
                  • Hoppy01
                    • May 2011
                    • 374
                    Ma post was directed at Hammerfrog who simply stated use a vacuum..
                    I never said squirt compressed air into a laptop, i assumed the guy was going to take the panels off it and give it a good service..
                    If he had done then putting a vacuum across it isn't a good idea, i didn't see your initial post..
                    But then 3 yrs at college and fixing PC's for 18 yrs, what do i know.....
                    • frank1982
                      • Jan 2013
                      download ccleanner installed and scan your pc
                      • XRay333
                        • Jul 2012
                        • 118
                        Not to start an argument here and I'm sure you've had a bad experience at some time with compressed air at a very HIGH PSI setting, but to say it's Silly is not very helpful IMHO.
                        I've been using compressed air set at no more then 30 p.s.i. for the last 20 yrs. by blowing the air thru(in) the exhaust vent and out the fan's intake without any problems. I would say to becareful and use the right technic as this can be very helpful and not IMHO SILLY.
                        Not only am I a "Certified HP/Compaq and Cisco Network Engineer" but I was a Team Leader in the "Pro Curve Network Division" of HP for 10yrs.
                        • XRay333
                          • Jul 2012
                          • 118
                          NO Vacumcleaners Please (except the little ones for keyboards). Your just asking for trouble in IMHO.
