Hi I have a PC with a C: drive 60gb and a D(data) drive 60gb, the C: drive has only 900mb of free space is there anyway of allocating some of the free space from the D: drive? as at the moment i cannot burn a DVD or copy one etc.. or is there another cheap solution to this problem? thanks in advance.
PC hard drive full
this program will allow u to add more or less hdd space from each drive
it is a partitioned drive and not two 60gb hdd's?
alternatively just buy a new hdd with usb caddy and/or a usb stickAttached Files -
there is the other method of getting rid of all the spare stuff off drive c as its clearly got too much on it at nearly 60 gig
the 60 gig data drive is where the data should be stored including films and music and files leaving c drive to run windows os and any programs too
but that easeus tool will definitely allow you to increase c drives and decrease d drive, but moving the unnecessary files from c to d is free, easy to do and frees up space on c drive too
you didnt say what os you are using but I cannot see anybody needing more than 50 gig for a c drive and there seems little point in filling drive c and having drive d emptyComment
Yea use the easeus app to do this and above advice is correct.
First, move some files around from C to D to create space, or delete stuff that you don't use or install again on the D drive.
The only thing that should be on the C drive is the OS.
All other apps , music etc, should be on the D drive.
Really your PC, is likely older model, so you should get a 500 MB usb drive and use this as storageTechnomate-Dreambox-SpiderboxComment
He wont store much on 500 mb flash drive,he would be better off getting a 500gb ehd.or replace the internal one for a bigger one....................I know you believe you understand what you think i said
I am not sure you realise that what you heard is not what i meant ! sigpicComment
Do as smoking writes about, and once that is done, you should run DiskCleaner. You find that under accessories > Systemtools. It will search your C drive for un-needed files, and give you the opportunity to delete them.
Once the C drive has been cleaned up, you will experience a performance boost if you run a diskdefragmentation tool on the drive. On some operating systems you will also find this tool under Systemtools.
For your OS to run smoothly, you should always have at least 15% free space on your C driveComment
You may have problems even moving or deleting stuff, Windows wants a minimum of 10% free disk space.
You may find you need to move/delete small stuff until the % increases.
Do you have a fixed or dynamic page file?? (Hint - 1-2GB fixed is best)
Switching it off and going into safe mode can sometimes clear enough space to give you room to sort out the problem.
Installing CCCleaner and running it can clear a lot of dead files as well, got rid of 20GB of "temp" files from a friends old 40GB drive!!!Comment
Get your self a bigger hard drive about 250GB and transfer all your data to a new hard drive and keep your smaller disk safe, there is a programme called Norton ghost that programme will copy all your data safe into the new hard drive.
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
hehe a typo, of course I meant GB as in 500 GB or even TB is an option these days.
First as mentioned, remove/move/delete stuff from C drive first, otherwise you can't take space outTechnomate-Dreambox-SpiderboxComment
Once you have removed some junk from your C: partition. Try changing the save location for your documents.
In most versions of windows you can right click on your documents folder & click 'properties'
In there you should find the save location. Just change it to D:\My Documents
If it doesn't prompt you to 'move/copy' the contents of the My Documents folder, you can do it manually.
But once done all things saved to your documents will go to the D: partition.Canker
like cranker saysOnce you have removed some junk from your C: partition. Try changing the save location for your documents.
or get a 1 TB sata drive for about ?60 or a 500gig for ?40 from ebuyer.com check this link
Cheap Internal Hard Drives From Top Quality Brands | Ebuyer.com
i have nothing to do with ebuyer i buy all my PC stuff from them because they are grate value i have used them for nearly 10 yearsLast edited by nsw9154; 1 February, 2013, 06:12.Comment
