deleting files from PC
  • rob6007
    • 152
    hi guys
    i set bought a new pc game , fifa manager 07 (ok its not that new)
    i have installed the game but it says i need "at least 768mb of free swap space , please free the required space and re-run the programme"
    how do i delete or free space . i chaecked my drives it says my c drive has 98.85gb free
    but my D drive only has 650mb free . so how do i delete or free space on my d drive so i can get this game running .
    been deleting unused programmes for the last 30 min but still no luck .
  • Jaffa
    • 1612
    You will need to free space on the drive you want to install it on, no matter how much you delete stuff on the other drive it will have no affect.
    It should be able to install on C: no problems. Just make sure when you are installing it that it says C: and not D:
    • rob6007
      • 152
      i have already installed it . should i uninstall then reinstall on c drive .
      is there a way to free space on d drive also jaff thanks
      • Jaffa
        • 1612
        Depends whats on your D: drive, seems very small with all the free space thats there. You could unistall in add/remove programs then try again. Have you partitioned drives or is D: the cd or dvd drive. ???
        I personally think the best way to clean unused files is to use CCleaner, its free and will keep your pc clean and tidy from clutter and temp files.
        • rob6007
          • 152
          my d drive is my cd dvd drive , it does seem very low space cinsidering i dont have myuch stuff on my computer .
          i will try uninstall then load back in again . can i choose where it goes into . c drive or d drive
          i will also get cc cleaner .
          will let you know how i get on thanks
          • Jaffa
            • 1612
            If D: is your dvd then it will always be low depending on what space is left on the dvd itself.
            When installing it will usually default to c: but it does ask you where you want to install it.
            btw...you wont be able to free any space on D: as it is either a cd or dvd.
            • rob6007
              • 152
              i unistalled it . reinstalled on c drive and it still wont open the game .
              still saying i need 768mb of free swap space , whatever swap space is .
              • rob6007
                • 152
                is there a way of making free swap space on my pc .
                how do i clear stuff to free space
                • Jaffa
                  • 1612
                  You may need to set your virtual memory manually.
                  Go to Start
                  Control Panel
                  Double click SYSTEM
                  click ADVANCED tab
                  In performance click SETTINGS
                  click ADVANCED tab
                  click the top settings button then advanced tab then change
                  Select CUSTOM SIZE
                  Then in the two boxes enter
                  INITIAL SIZE: 1024
                  MAXIMUM SIZE: 2048
                  Now click OK, OK, OK and restart PC if asked.
                  That is assuming you have at least one gb of ram, if you have more than 1gb then set it higher, the maximum size should be roughly double the initial size.
                  • rob6007
                    • 152
                    thanks jaffa , giving it a go just now
                    • rob6007
                      • 152
                      yeah thats it jaffa . games up and running thanks
                      • Jaffa
                        • 1612
                        Thats good news. Hope it was worth it.
                        • chroma
                          • 1976
                          Swap space is just additional ram in a sense.
                          its an area of your hard drive put aside by your operating system to use as storage for commonly used libraries, programs and dlls.
                          Its nowhere near as fast as solid RAM but it is faster than unloading common files then scanning through the rest of a drive to reload it again after a few minuites.
                          He who laughs last thinks slowest.
