INSTALLED XP TABLET PC EDITION NOW TOUCHSCREEN INVERTED
  • southerndragon
    • Apr 2010
    • 42
    Hello mates
    I recently got aN UMPC HEADSUN UMD708R2, VIA C7-M, VIA VX700 chipset. Wich has Win XP Tablet PC edition in chinese!!
    well I installed a copy of the XP Tablet PC Edition English language, But now the touchscreen is inverted!!. I mean when I touch the top side the cursor goes to the bottom, the same with the lef an rigth they are inverted.
    Also when I reinstall the original OS it works correctly.
    I didn't installed the graphic drivers, so I don't know if is related. Please I need some advice, I don't know what else to do
    Thank you very much
  • Reapers
    • 242
    well i did a quick look and a google search it mostly brings up Chinese models
    you can either change the tablet language and maybe the keyboard language options if need be on the operating system
    here is how you can access the language options then choose your preferred
    click Start,Control Panel, then on Date, Time, Language, and Regional Options, and then click Regional and Language Options
    also try to recalibrate the tablet screen
    • Open Tablet PC Settings by tapping the Start button , and then tapping Control Panel. In the search box, type Tablet PC Settings, and then, in the list of results, tap Tablet PC Settings.
    • On the Display tab, under Display Options, tap Calibrate. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    • Follow the instructions on the screen, and then tap Yes to save your calibration settings.
    • southerndragon
      • Apr 2010
      • 42
      Thank you for your prompt answer, well I've already tried that but the OS is in chinese and I think it doesn't have the english package installed, about calibrating the touch screen it works with the chinese OS but not with the english one, the calibration is also inverted, when i touch the point it doesn't work, it works only when I touch the opposite point
      Thank you very much
      • R_J
        • 492
        Can you install the touch screen driver from the Chinese version into the english version of the os.
        I also found this Download Microsoft Windows XP Tablet PC Edition 2005 Recognizer Pack from Official Microsoft Download Center
        Microsoft? Windows? XP Tablet PC Edition 2005 Recognizer Pack adds international handwriting recognizers to a Tablet PC or other personal computer
        • southerndragon
          • Apr 2010
          • 42
          Thanks mate, and How can I install the Touchscreen driver from the chinese XP to the english XP?
          Well al downloads from the Windows download center require that the XP must be installed in english
          Thank you very much
          • R_J
            • 492
            in the touchscreen setup (english version) is there a way to change the language to chinese, then do the calibration?
            I did find this for another touchscreen, maybe its driver would work http://www.eturbotouch.com/dimage%5C...2810105512.pdf
            page 17 had some info other than this I have no idea. This is about the best I can do to help you, maybe someone else as a better idea.
