XP Restore point problem.
  • Tvjunky
    • 74
    I have tried to use restore point, however I get the message:
    Your computer cannot be re-stored to:
    I have tried new re-store points getting the same message.
    I have checked re-store is switched on.
    Idea?s to solve the problem please.
    All Sorted now guys, Thanks.
    If you don't ask, you don't get.
  • Spudzz
    • 7
    I am having the same problem,would it have anything to do with using a cleaning tool like system mechanic.
    • port06
      • Jun 2009
      XP Restore.
      Hi Tvjunky,
      This prob rings a bell.
      Sometime back, using my old faithful Dell Dimensoin 3100 wih Norton internet security onboard,,,,,had similar prob.
      Found the answer in Compoter active, consisted of altering some settings temporarily in Norton at that time, and was then able to set Restore points as reqd.
      If required I can delve through Back issues to find exact fix for you.
      Or maybe simpler for u to google search....Good luck...
      Cheers, port06
      • Tvjunky
        • 74
        Yes could well be.
        Tried a so called FREE? Prog’ that would scan and find all errors, correct the errors and restore the computer so that it would run 70% faster.
        After downloading and running the program it refused to correct the errors until I paid a registration fee.
        I deleted the program instead.
        FREE to download. |Not FREE to use. Adware Pro Be careful.
        • Tvjunky
          • 74
          Originally posted by port06
          Hi Tvjunky,
          Cheers, port06
          Thanks Port06, however I am not using Norton.
          • Tvjunky
            • 74
            Still trying any Offers !!!!!!!!!
            • cunny
              • 4915
              I dont use the restore points at all, but i am guessing that its either been turned off under the system properties. Is there any particular reason you need to do a restore?
              If all your data is backed up on another disc/drive, i would be a format.
              • dasteph
                • 1293
                follow the link it may help you.
                computer won't restore - Tech Support Forum
                • Tvjunky
                  • 74
                  Another Link 2: FREE to download. |Not FREE to use.
                  • dasteph
                    • 1293
                    its not a download link, its a link to a forum page where you might find a answer to your problem.
                    • jgusteau
                      • Jun 2009
                      • 5
                      Retore Points are good... saved me a few times...
                      Microsoft link:
                      Use System Restore to Undo Changes if Problems Occur
                      Regards
                      J Gusteau
                      • Tvjunky
                        • 74
                        Yes Apologies, when you click the link you will understand.
                        All sorted now I turned off the restore, re-booted and switched restore back on.
                        Works fine now.
