ACER Laptop Problem
  • BluebirdCCFC
    • Aug 2013
    • 16
    ACER Laptop Problem
    Hi I have an ACER laptop that is around 2 years old and I have always kept very good care of it.
    I was using it this morning and it was fine, no signs of anything wrong but when I tried to turn it on tonight the screen just stays off.
    The laptop comes on and stays on whilst the charger is plugged in but still no screen. When the charger is not plugged in, it comes on for around 30 seconds and then goes off. (No screen comes on without the charger either.)
    Any help would be much appreciated.
    Look closely it might been the screen comes on but the backlight is staying off might b able to see a glimmer of the screen
    try booting the PC into the bios hold F2 or del on start up then you'll know for sure if its a duff screen or setting
    • BluebirdCCFC
      • Aug 2013
      • 16
      I have done that and the screen is definitely not coming on. Would a broken screen cause it to go back off after about 30 seconds?
      • willywonker2010
        • Mar 2010
        • 449
        what the model buddy
        also if it's got it
        VGA port
        or hdmi port
        try booting from those also
        • BluebirdCCFC
          • Aug 2013
          • 16
          ACER ASPIRE 5742
          I just tried connecting it to my TV via HDMI and VGA and nothing coming up.
            try booting to the bios can you see the screen or did the Laptop bleep more than one
            its sounding like it might be the video card died
            try some of the tips here from a similar problem - sorry the user is a bit dim
            http://www.justanswer.com/laptop/7b1...ven-using.html
            • Cod3waX
              • 1011
              sound like the gfx card has pooped its self it could be that its gotten to hot and fired itself off the board
              blocked fan heatsink and unmounted heatsink from gpu from expanded screw maybe or it could just be the screen cable has worn at the hinged and broken
              but at the moment u must take your hdd out! u dont want that spinning up and shutting down while trying to fix ur laptop
              also take out the ram and try booting the laptop and swap sticks and ports when trying (try it with none first)
              • BluebirdCCFC
                • Aug 2013
                • 16
                Thanks for all the replies. I left it on charge for nearly a whole day and it came on fine, and has worked fine since. Is it something I should worry about? (Nothing stored on there so no need to worry about losing files.)
                • Cod3waX
                  • 1011
                  maybe your battery isnt working properly or a system config tat tells the laptop to stay off until it reaches it certain programmed power storage ???
                  try booting the laptop without the battery
                  • Reapers
                    • 242
                    is this related to the other post? http://www.digital-kaos.co.uk/forums...top-363859/The
                    it comes on for around 30 seconds and then goes off. (No screen comes on without the charger either.) take your laptop
                    battery out and plugin charger in and turn on laptop does it stay on and does your laptop give pictures on your screen
                    like normally?
                    Would a broken screen cause it to go back off after about 30 seconds? maybe?
                    if it affects the cables? sometimes not sometimes you get the screen working one of those things
                    (worse case)could of been overcharged or left in badly vented condition
                    where heat got to the hardware maybe if it is hardware its most like the vram which is most common
                    part of the hardware on gpus
                    as for the black screen
                    thats most likely a software issue
                    either a corrupt driver issue or software configuration boot order/mbr need reinstalling/retyping depending
                    on your preference of fixing computers.
