WINDOWS 8 DELETED ITSELF FROM ACER LAPTOP
  • BluebirdCCFC
    • Aug 2013
    • 16
    Windows 8 seems to have gone from my ACER laptop. When I turn the laptop on it just says ACER and then says trying to find files but fails and turns back off.
    I have no discs to re-install so what is my best option?
  • mtv1
    The Stig PT
    • 4413
    is it under warranty ?? if not try torrent sites they have win8 and activators sorry against the rules to post links to torrent sites
    • BluebirdCCFC
      • Aug 2013
      • 16
      No the warranty has run out. Would it be possible to send a link in a private message, I am hopeless at finding torrents.
      • mtv1
        The Stig PT
        • 4413
        pm sent but might not work depending on what bb provider you have
        • BluebirdCCFC
          • Aug 2013
          • 16
          Thank you, so once its downloaded just load it onto a disc and boot the laptop from the disc is it?
            Great win today mate
            • mtv1
              The Stig PT
              • 4413
              yep you will also need an activator
              i recommend you put win 7 on it some of the win8 ones don't work tbh good luck mate
              • Reapers
                • 242
                if you had windows 8 currently pre-installed
                i would not recommend you delete it or install any other operating systems
                because unless you have your serials backed up you will lose them
                did you try recovery options ?
                acer hp sometimes store backup on a separate partition allowing you to access at boot
                by pressing certain keys with acer its usually ALT+F10 at start up
                • mtv1
                  The Stig PT
                  • 4413
                  but if its out of warranty it would not be legit to begin with as most lappies have a 2 year warranty and win 8 not out that long
                  worth a try do
                  • BluebirdCCFC
                    • Aug 2013
                    • 16
                    Thanks for the help, will let you know how it goes.
                    FAO Maca - It was a great win and a great day, I didn't expect nothing from it but I was completely shocked.
                    • BluebirdCCFC
                      • Aug 2013
                      • 16
                      The file won't fit on one disc, does this matter?
                      • 12345guy12345
                        • 162
                        you need a iso file type copy of windows 7, then burn the iso using img burn, choose burn img to disc and select the iso,when installing you may have to set the computer to boot from disc so you go straight into the setup mode then delete partion ,create new partion and install
                        • BluebirdCCFC
                          • Aug 2013
                          • 16
                          Been trying to get it working for hours, thanks for all the help but I failed, taking it to a repair shop on Tuesday.
                          • mtv1
                            The Stig PT
                            • 4413
                            nooooooooooooooooooooooooooooooooooooooo are you trying to burn it to a cd or dvd you need a dvd as the image is over 1 and a half gigs
                            ImgBurn - Free download and software reviews - CNET Download.com
                            burn with that
