I have recently changed Laptop and my new laptop will not connect automatically to my wireless router. I can connect manually to the router using the IP address but the VPN software does not work this way. Has anyone ever expirienced this problem ?
Aquiring network address
Hi bossman, welcome to the forum.
Try going into your control panel > wireless networks. Do a scan for available wireless networks or refresh the list.
Connect to your router if it's available on the list. If you have encryption enabled on the router you will need to know the access key or passphrase. After it connects, it should remember it and always connect. -
it sounds like ther eis a problem with ur network card settings. Right click on ur connection icon and choose ur adaptor. click on the advanced tab and check ur netwrok card settings. If this is set to obtain an IP address automatically then its a firewall issue.Comment
are you using the windows software or the manufacturers of the network card to make your network connection? Usually best to use windows . Before trying this delete the settings for your current connection completely! I have seen this problem several times, it has been different things includin Norton internet security (pah!) Good luck
RonComment
make sure dhcp is enabled on both the router and the laptop is set to obtain ip address automatically. Also, make sure you havent set up anything else like mac address filtering and that you are entering the encryption key right. After that i would disable any personal firewalls ie zonealarm or windows firewall just to make sure.
Sometimes, for me, i need to go to network connections and disable my wireless connection and then re-enable it.
Let us know how you get on.Comment
I do not want to sound cheeky mate, but check to see if your WIFI card in the laptop is switched on. I find in many cases the wireless antennae is not seeing ~~~~ all because there is a little switch on some laptops that enables you to power on and off your wifi and bluetooth for both security and power saving reasons.
Let us know if you have cracked it yet or whether you have launched the sucker out of the window..
On an IBM use press FN + F5, on some clones its a little slider switch...Last edited by caveman_nige; 1 May, 2008, 08:18.Comment
Hi, in my bad experiences with WiFi connection to my wireless router i have experienced the following:
1) DNS caching. Ressolved by going to command propmt and typing "IPCONFIG /FLUSHDNS"
2) Wireless channel mismatch. Ressolved by setting static channel on router to European setting of 11.
3) Existing IP settings in the properties of the network card. NOTE: Ensure that you are looking at the correct network interface settings. Ressolved by selecting the obtain settings option
Hope this helps in fixing your problem. Other provide more info on your router and your new laptop.
Good luck!Comment
