Slooooooow Pc
  • ste6106
    • Mar 2009
    • 444
    Slooooooow Pc
    Afternoon, My grandads Pc ir running really slow, takes time to boot up and then takes ages for the connection to start and its slow navigating through the internet eventhough broadband and is a good connection, think it may be problem with some stuff he has got stored in here thnik may need to clean it up, best way to do this please???
    Ste
    Life is a party and parties arent meant to last.
    first get rid of everything u can, then clean the reg i use ncleaner, free windows registry repair, and ccleaner all free, also do a defrag, and run an antivirus, malwarebytes, and a-squared free r good, u also might need to add more ram
    • bigfella
      • 879
      how do u add ram??
      • AL.baby
        • Jun 2009
        Disk clean-up
        Best way to clean stuff is to do a disk clean-up i think this is in the control panel or you could just search it on your computer.
        It is safe way of cleaning things o you system so that the computer will run smoother.
        • dasteph
          • 1293
          Originally posted by bigfella
          how do u add ram??
          random access memory (ram) depending on your motherboard what type of ram it will take and also the maximum amount your board can use it is one of the ways to speed up a pc, to add it you need to open the pc up.
          • ste6106
            • Mar 2009
            • 444
            Ta guys will post back should I need extra help
            • cunny
              • 4915
              If there is nothing/little worth saving, consider backing it up and formatting it.
              I generally do this quite often but not as bad now upgraded.
              • ste6106
                • Mar 2009
                • 444
                Chhers GMB ran a few clean up programmes, worked a treat
                • smooth
                  • Jun 2009
                  This would be the best option as you would have installed the operating system from fresh.
                    how do u add ram??
                    ram is your working memory, u go to shop buy some take back off the computer and stick it in, simple
                    • Chimaera
                      • Jun 2009
                      • 242
                      Not wishing to be picky.
                      But i would take the back of first and find the memory sticks, check whether there is spare slots, if there isnt get the motherboard number its stamped into the mobo google it and read the specs for your board see what max allowance is and check what you have in, it tells you on the memory sticks what size they are.
                      Then goto the shop and buy some if you have the space or can replace with bigger ones
                      Just my thoughts
                      http://www.simple-software.co.uk/
                        Just my thoughts
                        hmmm maybe i was a bit vague, take the 1 from your computer to shop m8 make sure u get the right 1
                        • mickydibble
                          • 2166
                          whats a "mobo" thnx mick
                          • MetalKettle
                            V.I.P.P.T. Member
                            • 797
                            Motherboard m8.
                            XBMC/KODI Developer
