boistar motherboard help
  • bajanboy
    • 18
    hey guys I have a p4m80-m4 biostar motherboard with a celeron 2.26ghz (133x17.0)cpu and 512mb @ 333mhz memory so I cleared the cmos and updated the ram to 2x1gig pc3200 @400mhz now the cmos is saying Warning cpu has been changed or cpu ratio changed fail please re-enter cpu settings in cmos...
    press f8 to enable system coniguration
    press f9 to select booting device after post
    press f1 to continue, del to enter setup
    when i go to the bois the current FSb it says 133MHz and Dram says 100MHz any ideas why???? I think it shouls be saying 533 fsb but not sure.everytime i restart i have to keep pressing f1 for computer to load.
    Need Help Please Thanks.
  • cunny
    • 4915
    replace battery and do a reset
    • bajanboy
      • 18
      ok thanks for the reply but now it wont post I remove battery and reset it now the fans just spin for a few seconds and stop and it wont come on any more??????
      • chroma
        • 1976
        replace the old memory
        see if it boots.
        Then update the bios BIOSTAR and then try the different memory modules.
        He who laughs last thinks slowest.
        • bajanboy
          • 18
          I replaced the memory and updated the bios already
          i tryed another power supply and it still wont come back on
          I think it might be dead
          • Sirus
            • 340
            My old motherboard screws up all the time when I add new things or unplug replug the HD and stuff and once its starts going funny it usually for some reason begins to just not post anymore
            So what I do is keep removing batt or just reset the bios jumper then re arm it... you may have to do this a few times for a couple of days before it posts again
            Ive had to do this about 6 times over about 5yrs of having the motherboard and was gonna bin it loads of times but after long it begins posting again
            Mine is a PC Chips board... put the bios jumper on reset bios for a day or 2 then back to normal setting see if it posts
