Laptop only works with AC power?
  • lee_hdi
    • 928
    Hi,
    I have an issue with my Dell laptop, with that it only works when plugged into the mains.
    The battery has been replaced and shows as 56% full on the power options, but doesn't seem to charge past this.
    The laptop won't turn on without the AC adapter even thought the battery is at 56%, and as soon as you unplug the AC adapter the laptop turns off.
    Is the motherboard shot?
    Thanks,
    Don't let failure go to your heart, don't let success go to your head.
  • ttzag
    • 1907
    First check your charger and battery in bios .
    Second try another charger
    Sent from my HTC One using Tapatalk 2
    Actions speak louder than words
    • worcestersauce
      • 136
      Originally posted by lee_hdi
      Hi,
      Thanks,
      Sounds very much like the battery mate, Had similar problem with daughters laptop.....her battery was showing 100% charged but it would only work on mains. Theres some videos on youtube about re-calibrating the battery to the laptop (take battery out, plug in and switch on without battery, insert battery,restart,etc..) but tried a few things on daughters but still no joy. It was a faulty battery in the end (new one on way thankfully)
      • jhon silva
        • Sep 2012
        • 59
        may be the electrical contacts pc, must have something to wear when he is old pc
        • insomnia2009
          • 703
          i would suspect a mosfet problem or charging ic contact me if you want some help with it
