SystemRescueCD v4.0.0
Bootable CD-Rom for repairing your system and your data after a crash.
SystemRescueCd is a linux system on a bootable cdrom for repairing your system and your data after a crash. It also aims to provide an easy way to carry out admin tasks on your computer, such as creating and editing the partitions of the hard disk. It contains a lot of system utilities (parted, partimage, fstools, ...) and basic ones (editors, midnight commander, network tools). It aims to be very easy to use: just boot from the cdrom, and you can do everything. The kernel of the system supports most important file systems (ext2/ext3, reiserfs, reiser4, xfs, jfs, vfat, ntfs, iso9660), and network ones (samba and nfs).
System tools included:
You can also browse the detailed package list if you want to have a full list of the packages you can use here:
Code:Select all
http://www.sysresccd.org/Detailed-packages-list
Advanced usages
SystemRescueCd is available for blind people. Now, the linux speakup version 1.5 screen reader is working well, and the speakup keymap is installed. This feature was tested by Gregory Nowak.
It is possible to make customized versions of the disc. For example, you can add your own scripts, to make an automatic restoration of the system. It's also possible to burn a customized DVD, with SystemRescueCd and 4.2 GB for your data (backup for example). Read the manual for more details.
It is very easy to install SystemRescueCd on an USB stick. That's very useful in case you can't boot from the CD drive. You just have to copy several files to the stick and run syslinux. The install process can be done from Linux or Windows. Follow instructions from the Manual for more details here:
Code:Select all
http://www.sysresccd.org/Online-Manual-EN
Check ChangeLog here:
Code:Select all
http://www.sysresccd.org/Changes-x86
See some Screenshots here:
Code:Select all
http://www.sysresccd.org/Screenshots
Homepage and more info here:
Code:Select all
Download it from here:
Code:Select all
Download - SystemRescueCd
or
Download SystemRescueCd from SourceForge.net
or
http://kent.dl.sourceforge.net/proje...-x86-4.0.0.iso
- GParted is a Partition Magic clone for Linux.
- GNU Parted is the best text tool for editing your disk partitions under linux.
- Partimage is a Ghost/Drive-image clone for Linux.
- File systems tools (e2fsprogs, reiserfsprogs, reiser4progs, xfsprogs, jfsutils, ntfsprogs, dosfstools): they allow you to format, resize, debug an existing partition of your hard disk.
- Ntfs3g: allows you to mount your windows partition and get a full read/write unlimited access to the ntfs partition.
- Sfdisk allows you to backup and restore your partition table.
- Test-disk tool to check and undelete partition, supports reiserfs, ntfs, fat32, ext2/3 and many others.
- Network tools (Samba, NFS, ping, nslookup, ...).
Code:Select all
Advanced usages
Code:Select all
Code:Select all
Code:Select all
Code:Select all
Code:Select all
or
or
