Vista user account locked?
  • eyeballs
    • 54
    My supervisor has a home desktop running vista, all the family use it as the same user, one of his daughters put a password on it at the weekend but cant remember what it was. I remember reading that in xp you could go in thru' the command prompt and change the password and was wondering if the same could be done in vista? bear in mind he cant get past the login screen. Or if anyone has an easier/ better way of doing it without the use of password crackers or programs like that.
    Red And White Till I Die.
    Come on the 'Pool
  • dasteph
    • 1293
    You should be able to re-boot in safe mode and log in as the built-in
    administrator. This account generally doesn't have a password and is only
    available in safe mode.
    From there, you can get to User Accounts and change passwords.
    When your restart your computer, press F8 right before you see the Windows
    splash screen. This will bring up the Advanced Boot Options menu, from which
    you can select Safe Mode.
    • cunny
      • 4915
      Originally posted by Tonymc49
      looking for larel and hardy ringtone ???
      I dont hink this is a valid 1st post and as for laurel and hardy( you cant even spell it right) check here............Laurel & Hardy - The Official Website
      As for your problem with vista, doing the above will be fine if no admin password as been set, if so you will need a password recovery program for this situation, get back to us and i am sure someone will know 1.
      • smirnoff_rules
        • 8603
        deleted it m8 .. dont know wot he was thinking
        • cunny
          • 4915
          thanks mate, wound me up that as he has a genuine problem. An BTW smirnoff_rules!!!!!!!
          • eyeballs
            • 54
            Thanks for the help guys, i've passed on the info and will let you know how he got on
            Come on the 'Pool
            • eyeballs
              • 54
              have feedback. he booted in safe mode and tried to log in as admin but it said the admin account is disabled. I asked him to try remove the password in safe mode but it wouldn't allow it. is there a way to enable the admin account ?
              Come on the 'Pool
              • dasteph
                • 1293
                the following link tells you how to enable the admin acc in vista, still use safe mode as before and give it a try.
                Enable Vista's hidden administrator, and password-protect its XP equivalent | Workers' Edge - CNET News
                • eyeballs
                  • 54
                  thanks for that, I passed on the link to him but he's not been back to work since so I don't know if he managed to get it going
                  Come on the 'Pool
                  • Curious123
                    • 2591
                    If all fails then you could always look for the ERD Commander cd or Winternals cd and reset the admin password.
                    • mk7975
                      • 9
                      use ophcrack always works.
