Weird Virus
  • acestu
    • 269
    Weird Virus
    Hi guys, ive got a lappy running xppro and just recently tried to open live messenger to contact another member, now it says service temp unavailable, so i uninstalled it and reinstalled latest version and same thing, also i cannot access the microsoft update site it says there is a problem with the site, i have ran avast and nothing then i used bitdefender and nothing, malwarebytes and nothing so do you think it may have corrupted a windows file ?
    cheers
    Acestu
    If my post Helps, then Please Click the THANKS Button ,as i will do for you.
    The Acestu Corporation.... More Powerfull Than You Could Possibly Imagine !!.........sigpic
  • cunny
    • 4915
    cheers
    Acestu
    check your port setting, cant be more on ball sorry
    • acestu
      • 269
      ok
      ok m8 i will have to do a bit of research tommoz, taa anywat..
      cheers
      Acestu
      • satsmo
        • 6397
        Sounds like a DLL reg problem. Use this small freeware prog
        http://majorgeeks.com/Dial-a-fix_d4899.html
        it should sort out the problem.
        Leave all boxes ticked at default and let it run. It will not do any damage to your OS.
        • acestu
          • 269
          Yes that,s exactly what it was Satsmo i found a batch file that re registered all the dll files early this morning, but thanks for the reply anyway, if anybody else has this problem it worked for me.
          cheers
          Acestu
