Boot Windows 7 iso from USB Stick..??
  • opsmonkey
    • 5379
    I have a Windows 7 RC iso from microsoft, trouble is i dont have any DVD's left..
    Can i somehow boot it from my 8GB USB Stick or External Drve..????
    Not 100% sure m8 but can't you extract the iso to your usb stick and set the bios to boot from usb ? Assuming your bios supports that option.
    Or Extract it to your HD on your pc using isobuster, and install it from there.
    • opsmonkey
      • 5379
      i dont know if its best to put the iso on the USB or extract all the files to the stick..??
      My HDD will boot from USB in BIOS
      • Curious123
        • 2591
        I have done a number of pc's so I have forgotten how loaded half of them but I am sure that you can extract all the files to your USB and install from your USB.
        • smirnoff_rules
          • 8603
          if u make it bootable using HP USB Disk Storage Format Tool - v2.1.8 Download - EXTREME Overclocking and then drag all the files over it might work
          • opsmonkey
            • 5379
            Cheers smirnoff, that hasnt worked.. just came up with non system disc error..
            anyone else have an idea..???
            • chroma
              • 1976
              try formatting to make it bootable by installing dos
              then copy the files from the iso over.
              Then when it boots just use dir /p /w and look for the setup exe
              execute that and see if that works.
              He who laughs last thinks slowest.
              • chroma
                • 1976
                sry for the doublepost but ive found this:
                Make your flash drive bootable using Bart's mkbt util:
                MKBT, Make Bootable | Alt: mkbt20.zip
                Put a bootable floppy disk in your A: drive or create one using Windows.
                Download mkbt20.zip and unpack to to new temp folder you create.
                Go to the temp folder.
                Extract the bootsector from the bootable floppy disk. eg Open a DOS Window and go to the directory where you extracted MKBT. Type:
                mkbt -c a: bootsect.bin
                The boot sectors from the bootable floppy disk have just been saved to a file in the temp folder you created.
                Format the flash drive in FAT or FAT16.
                Copy the bootsector to the flash drive. Open a DOS Window and go to the folder where you extracted MKBT. Type:
                mkbt -x bootsect.bin Z:
                "Z" represents the flash drive drive Letter. So if your flash drive has another drive letter, then change the "Z" accordingly.
                Now you can [grin] "should" be able to copy the utils you need to the pen drive.
                • opsmonkey
                  • 5379
                  install dos where..??
                  Im on Win Xp at the mo..
                  Ahh.. thanks but i dont have a Floppy Drive
                  • chroma
                    • 1976
                    First if you don't have a physical floppy drive (and don't want one) you can use the [free] "virtual floppy driver" from here:
                    VM Back
                    With that you get an A: drive and can manipulate a floppy image as if you were using real floppy. You can then use that image to make a bootable CD. It's not that user friendly but once you get how it works it does work perfectly.
                    • caveman_nige
                      • Feb 2008
                      • 4920
                      am not gonna copy this over, its best you just follow the tuts in these links bud...
                      the authors deserve all the credit..
                      For XP
                      http://www.liliputing.com/2008/04/install-windows-xp-on-mini-note-usb.html
                      For Vista and Windows 7
                      http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
                      you may need to mount your iso first as you have no DVDs left, you can do with with a download of the trial version of daemon tools..
                      • opsmonkey
                        • 5379
                        thanks Chroma, that looks a bit complex for me..
                        hopefully there will be an easier way..
                        The USB pendrive gives me the Windows Setup icon when plugged into my PC..??
                        Cheers KV i'll give it a bash now
                        • opsmonkey
                          • 5379
                          this is a nightmare.. when i choose "run as administrator" it asks for a password..
                          i dont have one.. the only user account listed on the pc is mine and it says i'm the computer administrator.. if i try to change the name to administrator it says "account already exists"
                          WTF..??
                          • caveman_nige
                            • Feb 2008
                            • 4920
                            at what point in the process does it ask you this m8?
                            • Saltire
                              • 1361
                              ops, let us know how you got on after the wee chat we had on shoutbox.
