help with installing ram
  • mickydibble
    • 2166
    #16
    Could it be if the xp service packs weren't upto date?m
    • cunny
      • 4915
      #17
      Can you post motherboard specs and new ram specs please
      • dasteph
        • 1293
        #18
        Originally posted by mickydibble
        Ok thnx ,I will but got to cover postage to china/and wait what memory can I get for this motherboard in this country? Thnx again
        the following link to ebuyer will give you an idea what memory will cost this is all 2700 the other memory that your mobo will take will probably a bit cheaper also a lot closer than china.
        Desktop Memory | RAM - Ebuyer
        • mickydibble
          • 2166
          #19
          hi the mobo specs can be found here: ASUS A7V333 Motherboard - Product details and features - DealTime
          the ram specs: MEMORY CAPACITY: 1GB
          MEMORY SPEED: PC2700/333MHZ
          MEMORY TYPE: DDR RAM 184pin
          FEATURES:Unbuffered, Non-ECC, Non-Parity, high density
          main circiut board: Board: ASUSTeK Computer INC. A7V333 REV 1.xx
          Bus Clock: 100 megahertz
          BIOS: Award Software, Inc. ASUS A7V333 ACPI BIOS Revision 1015 10/29/2002.
          could it be the bios needs upgrading?? thnx guys mick
          • mickydibble
            • 2166
            #20
            hi found this info on a bios update higher than mine but dont understand but mentions about unreported memory.however i dont understand the pdf info??? i have attached the info thnx mick
            it says:A7V333 BIOS 1016 -(this is one higher than mine).
            Support new CPUs. Please refer to our website at: http://www.asus.com.tw/support/cpusu...pusupport.aspx
            Fix that sometimes system hangs when using ATI VGA card.
            Fix HCT 11.x error of "Unreported Memory."
            • mickydibble
              • 2166
              #21
              come on guys help help meeeeee
              • caveman_nige
                • Feb 2008
                • 4920
                #22
                dude, you probably have shite chinese ram by the sounds of it... send the crap back and buy in this country that way when you have an issue its easy to get support and send it back... If you want to flash the bios with a later version which is what i would do when the there is a newer one do it, it will not harm your system just iron out some existing bugs and replace them with newer ones.. In previous machines i Have found that flashing the bios allowed me to run with more ram , faster cpus and bigger HDDs.. You have nothing to loose..
                In the past I have bought ram for my old dell, i even took the chip to the shop to show them what i wanted, i still ended up doing three trips due to bad ram...
