harddrive recovery
  • Time2Play
    • Apr 2009
    • 309
    harddrive recovery
    hey all i had the BSOD so i used kill disk to blank the harddrive but the problem is i had a foldr with impotant format things on desktop i was wandering whats the best program to recover this??
    SAY THANKS OR JOK WILL TAKE PICTURES OF YOU IN YOUR SLEEP
  • dctyper
    • 2539
    you cant if you used kill disk matey
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
    • jfish
      • 799
      does kill disk do a full wipe of hard disk but writing 0 on all sectores multiple times, if so no chance of getting data back.
      I know may be a stupid question, but why didnt you back up your data before do the kill disk application.
      people tend to forget about backup strategy (only saying this as I work as a backup specialist).. to recover data from any media can cost up to 20k (yes done this years ago when a tape we had wouldnt read and had to send it off to a company to recover data and they charged 20 thousand pounds)
      • Time2Play
        • Apr 2009
        • 309
        hey i wish i could but i had the bsod and could not recover it and only way was to kill the harddrive to install a new operating system kill disk was the only program i had in hand i did a quick format tho but no luck to recover :'( and i lost something important
        • dctyper
          • 2539
          bsod! just put the hdd in another pc matey, then copy across. i know this dont help now, but maybe next time
          • kiwi76
            • 41
            I have recently recovered data from formatted harddrive's with a superb program, quite simply called "Recover my files" do a google search it does cost to buy but if you know where to look it's free!!
            • mickydibble
              • 2166
              it could work but maybe a kill drive is different to a format but it does a full format recover-__ it is worth downloading but a point is you need a separate drive to recover too...not the formatted drive. worth a try
              • cunny
                • 4915
                Kill disk works in a differant way than doing a format. So i doubt will be recoverable data worth scanning for. Also dont forget when you format you are formatting to the os, ie linux/win/apple based, all differant
                • dik
                  • Apr 2009
                  • 955
                  http://www.digital-kaos.co.uk/forums...s-probl-51399/ Free today only
                  sigpic another happy customer
                  Sent from my keyboard using fingers to type
                  • ManofScience
                    • 650
                    Get the original XP disk, put it back in, Select new install (not recovery console), it'll detect the previous windows installation and then select 'Repair'. Job done, it re-installs over the top. Replaces the system files yet leaves your data and program files in tact - including drivers, settings, emails - everything.
                    killdisk is designed specifically to make sure nothing can be recovered from it. you have no chance of getting anything back.
