a file i canot open tia.
  • jonnboy
    • 57
    hi ,guys ,im trying to open this file without any luck,please help 00000002.000 (76.4 KB)
    they are file to do with the knowledge (black cab driver)
    thanks Jon
  • smoggy
    • Apr 2009
    • 12772
    try renaming it to end in .txt and then double click on it and see what happens
    • jonnboy
      • 57
      no joy sorry m8.
      thanks Jon
      • smoggy
        • Apr 2009
        • 12772
        I would expect the knowledge to be probably text and maps so maybe its a map and you need the software to run it
        • jonnboy
          • 57
          its def roads ,it should be a pdf file but its not.
          the rambles are a load of routes between each embassy to the next one and so on.
          thanks Jon
          • dasteph
            • 1293
            thanks Jon
            researching this type of file it appears that it is to do with log parsing whatever that is the link will tell you how to open it but seems to be very complicated.
