Dell Lattitude D630 password help needed
  • Arnolt
    • Aug 2014
    • 11
    Hi, i have an old Dell Lattitude D 630 that I almost threw away already until I found this forum. if someone could help me with a password which is lost few years ago. Service tag is JLJBW3J-595B
    I would really appreciate the help
  • smoggy
    • Apr 2009
    • 12772
    try 4nvfig0p 7th is a zero
    • Arnolt
      • Aug 2014
      • 11
      this password didn't work on my Dell,any ideas why not? But thanks anyway...
      • smoggy
        • Apr 2009
        • 12772
        password given is correct for that serial
        The password is the master password to get into BIOS
        • Arnolt
          • Aug 2014
          • 11
          That is a problem because i can't get in there ...more likely i don't know how to do it.If you can give me step by step guidance how to the proceed. And thanks again for your time and efford.
          • Arnolt
            • Aug 2014
            • 11
            There is also a sticker below the machine where is Express Service Code 461-611'215-99 and there is that same service tag which i gave to you earlier.
            And i have tried to use external QWERTY keyboard but i can't make it work. But i am not sure that did i use this password in a right way because some so called " expert " here said that i have to press certain combination of keys at same time to get in to BIOS.
            • Colsnr
              • Oct 2013
              • 13
              If you install a new OS this should sort it.
              • Arnolt
                • Aug 2014
                • 11
                That's what i tried to do first. ( almost 2 years ago ) i went to the local PC store and i bought new win 7 home premium because there is Vista installed , but installation did not start. It just asking password.
                Maybe i should hacked it by axe i think this method clear all passwords ( Seems to be little frustration in the air)......... but no i won't give up.
                • smoggy
                  • Apr 2009
                  • 12772
                  to get the Bios screen you have to press certain keys whilst starting, I don't know what it is on yours but it is generall either the F2 or F8 or F12 and sometimes delete key.
                  try each one. Boot computer and straight away keep tapping one of these keys
                  • Arnolt
                    • Aug 2014
                    • 11
                    Yes i know It is F2 to Setup and F12 to Boot menu and i have try tapping on those keys many times whilst booting but only thing what happen is the grey screen where reads " This computer system, #JLJBW3J-595B, is protected by a password authentication system . You cannot access the data on this computer without the correct password.
                    Please type in the systen or administrator password and press enter"
                    but there ain't no place where to write the password and that's weird to me but however when i have wrote the " invisible" password Next note comes up "Invalid password Press ENTER to retry" and that's it. It let me try three times and then shut dow.
                    And I'm sorry for my English but I try my best to explain the problem, thank you for your patience.
                    • smoggy
                      • Apr 2009
                      • 12772
                      are you entering password in lower case as it has to be entered exactly as given
                      you could also try Ctrl+Enter or Shift+Enter after inputting password
                      • Arnolt
                        • Aug 2014
                        • 11
                        Yes exactly as given and 7 th is a zero and now i am tried to use these keys but no success
                        • Arnolt
                          • Aug 2014
                          • 11
                          I thought could it be any other password that I could use or is this only possible ?
                          • smoggy
                            • Apr 2009
                            • 12772
                            providing you have posted the correct service tag the password given is the master password and it will override all other passwords
                            • Arnolt
                              • Aug 2014
                              • 11
                              It is correct tag. But at the weekend i found from internet [dell.exe] software and it gives me exactly same password as you gave me earlier.
                              Now wondering here, is it possible that whole BIOS is corrupted ????? Or something else fault on my PC . Because seems that these passwords works to all the others
