FIREWIRE CARD
  • mahf51
    • Jun 2009
    • 114
    FIREWIRE CARD
    hi
    i have a firewire card installed in my pc i can see it in device manager with no explanation marks i am trying to connect my sony mini dv camcorder it is not being picked up i dont now why.the firewire cable is 4 pin which connects to the camcorder and 6 pin which connects to the port at the back of the pc. i dont no whether you need a 4 pin to 4 pin for this to work.please i need help soonest before i break this computer up
    mayfuze
  • nevovx
    • Aug 2009
    • 156
    Dont have much experience with firewire but i believe they are similar to network devices , what i mean is they also have an ip address and shows up in network category in windows. Could it be firewall blocking an access. Sorry just trying to be helpfull in something i havent used...
    if you perhaps run "ipconfig /all" in command prompt and find the ip address for your firewire and try pinging the ip number to make sure firewire is working and responding fine.
    • chroma
      • 1976
      Nah the interface is just like USB, totaly plug and play, no need to configure anything even remotely network related.
      I had the same problem at one point, turns out that i had to enable the firewire port on my camera though.
      Are you sure its been enabled in one of the menues? as i know first hand that occasionaly its not enabled by default.
      He who laughs last thinks slowest.
      • Old Man
        • Aug 2009
        • 35
        Another option could be to plug it into a different pci slot as resouces could be conflicting even though it is installed correctly.
        Just a side note i have one aswell and i had to install a disk that came with it even though it was listed in device manager; this was to allow my digi camcorder to run with the video editing software so maybe different chipsets of firewire cards might need different setup options.
