i but it didn't work. I got a message saying ''the windows on this computer is current you cant install old version of windows'',
what is the way forward?
many thanks.
Go onto a torrent site and download a version of xp from there, burn it onto a disk and then put the disk into your computer and start the install process.
stick the disc in your cd drive turn on computer while its booting tap esc when your in boot menu select cdrom, then follow on screen instructions, when your promoted select format hdd to ntfs ( not quick format ) then just follow the on screen instructions, this will take a few hours as your doing a full format and install.
ps. dont bother with torrent site unless you can help it, if you use a torrent get an iso which needs to be burnt to disc in iso format.
