Diskeeper/defragment problems.....
  • Saltire
    • 1361
    ive been using the program "diskeeper pro 2008" to defragment my drives and it works great.
    BUT, its a crack copy i have and it stopped working, so i tried to reinstall it etc and still it was no good, so i downloaded another copy of the cracked version which i think is just the same as what i have anyway, and it still didnt work, so i uninstalled it.
    Problem i have now though is that i cant even defragment my drives using windows built in defrag utility (which i believe is made by diskeeper too), when i try and do it the windows way it says "no defrag tool is currently installed".
    So what do i do guys, is there a way to sort this or maybe even another defrag program as good as diskeeper or possibly even better ??
    p.s
    its windows vista i have.
  • Devilfish
    Administrator
    • Feb 2008
    • 7872
    Maybe try a different keygen or serial to get it working?
    Or get a registry cleaner to clean all existance of the previous install; Registry Mechanic is good.
    • Saltire
      • 1361
      i tried Ccleaner, i think that does the registry too, not sure though, the registry is summit iam not keen in messing with as you know what can happen should things ~~~~ up, .
      And the keygen and serial, well there aint one, its a file you copy to the install folder, one of those ones.
      <--Thomson added 356 Minutes and 21 Seconds later...-->
      ok, i downloaded and installed the latest version of registry mechanic, ran a scan and fixed all problems etc, but still the diskeeper program is no good, it doesnt give me the option to "never register" etc, thats where the problem lies, am i using the registry mechanic properley ??
      how do i know if its removing the all the remaining parts of diskeeper ? it found about 300 problems, i cant go through all them one by one looking, so i just says to repair the lot and it did, but like i says, still not getting any joy
      Maybe i should just use another disk defrag program, probably quicker, , anyone know of one thats as good or better than diskeeper ?
      <--Thomson added 0 Minutes and 34 Seconds later...-->
      anyone ???
      • aftermath
        • 4345
        clean the old programme from your registry
        Start, all programs, Accessories, run
        type in regedit and delete any folders, strings that represent the old reg cleaner,
        Then check that the software folder has been deleted in your programme files folder too.
        then try to install the newer one
        • Saltire
          • 1361
          its ok chaps, thanks for your helps anyway but i found a great wee program and got the crack version of it, its called "AUSLOGICS BOOSTSPEED" its great, does allsorts of thing built into one including great defragmenting, and whats really really good is its so user friendly that its just excellent, i cant boast about it any higher to be honest, get it and try it and youz will see what i mean, i suggest everyone else does too.
          • billyb33r
            • 5
            You could have tried .. start + run (windows button + r) and dfrg.msc
            Contig v1.54 from sysinternals is a handy command line defrag tool.
            • Saltire
              • 1361
              its cool mate, thanks anyway mate, but you should try the program i just posted about above, its superb, iam well impressed, if you or anyone wants it just gimmie a shout, i have it here.
              • Saltire
                • 1361
                i emailed the program to user "mini", how did it go mate, you find it as good as i did ?
                • pabble
                  • 10
                  i had a similar problem using this program, at first wasnt sure it was to do with vista but more than likely it will be the crack, i swapped to perfect disk 8 and all is well now
