usb not recognised
  • scotty1965
    • Jul 2013
    • 116
    usb not recognised
    hi had my usb stick in my toshiba laptop on sunday then suddenly a message popped up usb has malfunctioned now when i put the usb in a message says usb not recognised can anyone help
    cheers scotty
  • HeXor
    • Jun 2015
    • 114
    New usb stick...usb memory dont seem to last too long...try a diff usb stick and see if it reads it
    • scotty1965
      • Jul 2013
      • 116
      Hi it's not the stick it's the usb port on my laptop tried all my sticks which previously worked ?
      Cheers
      • sohaillf
        • Jul 2015
        • 9
        Best to uninstall the usb drivers in device manager and reboot.
        • scotty1965
          • Jul 2013
          • 116
          tried that still the same
          • smokin
            • 255
            Yeah seems to be a common issue, depending on where the pc sits........ since the usb port is open, the contacts are open to the air and they can get a film, or just go off the connection points...oxidize perhaps...but no longer readable.
            How to fix...not sure, try a cotton ear swab... rub Inside the port...(light rubbing alcohol or such) the external connection is bad, not the port normally
            Technomate-Dreambox-Spiderbox
            • M T Glass
              • Jul 2013
              • 733
              Hi scotty, Lately I've been having the same problem with one stick and am sure it is wear on the part of the stick.
              Bought on of those usb adapters, not expensive...maybe a few pounds, and the stick works perfectly because the usb cable is a tight fit with the computer because it's new and the stick likewise, is tight in its new port.
              Official Meat-Head Fan Club Member (member number 14300)
              • Bann32
                • Oct 2011
                • 518
                Do other devices work if plugged into the usb port you are having an issue with? e.g. keyboard, mouse etc...
                Try all drivers relating to the usb port using USBDview
                Full info
                http://www.nirsoft.net/utils/usb_devices_view.html
                checked using virus total online report here -
                https://www.virustotal.com/en/file/1c1cfe6786e8b7618ab9c0c3b5bd43cbdcd131f01fd38bae258016aa53aa4fdf/analysis/1437258375/
                usbdeview.zip
                • scotty1965
                  • Jul 2013
                  • 116
                  hi thanks for all your replys but the other week the screen on my laptop went black totally nothing coming on the power button lights up and I can hear the fan and the harddrive making a noise but nothing coming on ? I even tried connecting it to an external moniter but nothing ? I think the motherboard has gone ?
                  thanks scotty
                  • DOUGALMCD
                    • May 2011
                    • 3229
                    Was it overheating before? try dismantling and check heatsink and fan not clogged if so repaste cpu as well.
                    • scotty1965
                      • Jul 2013
                      • 116
                      No it was never overheating?
