IBM thinkpad
  • alex77vl
    • Mar 2010
    • 367
    IBM thinkpad
    hello ,
    i have a ibm thinkpad and i have bios password
  • hacko12
    • Mar 2010
    • 501
    If the ThinkPad cannot be booted, reset the IBM ThinkPad password via hardware.
    If only the power-on password is set, do the following to remove the power-on password.
    1. Power off the computer
    2. Remove the DIMM cover on the bottom side of the computer.
    3. Short circuit the two password pads or put a jumper on the contacts to short the circuit.
    4. Under the short circuit condition, power on the computer and wait until the POST ends. After the POST ends, the password prompt does not appear. The power-on password is removed.
    5. Reinstall the DIMM cover.
    If both the power-on password and the supervisor password are set, do the following to remove the passwords:
    1. Press and hold F1 to power on the computer.
    2. Enter the supervisor password. The Easy-Setup menu appears.
    3. Click the Password icon.
    4. Click the Power on icon.
    5. Enter the supervisor password and press the Space bar.
    6. Press Enter twice.
    7. Click Exit then click Restart.
    If I helped you, you may use thanks and reputation button on my post. Thank you!
