see when setting up an adsl modem for the first time (which i have never done).
Is it the same as cable modems like if you use an ethernet cable instead of the usb cable you then dont require drivers/setup software etc ??
Also, if its a wireless modem/router, will it have the option to hardwire it using the ethernet cable rather than only wireless option (i dont like wireless).
and finally, the phone socket that the modem uses, if theres no phone getting used on that socket, does that socket also require a microfilter even though theres no phone getting used on it ?
