dell latitude d630 admin password ??
  • delmumbles
    • Feb 2012
    #1576
    Opps - wrong tag
    Thanks to JustMeAgain for the password
    Spent 10 minutes trying to get it to work before I realized that I had a typo in the Tag I gave - My Bad
    The correct Tag is D3L7Z3J-595B
    could you please get me a password for the correct Tag
    Sorry for the balls-up
    • fredskidoo
      • Jun 2011
      • 10
      #1577
      Dell C610
      Hello
      Took me a minute to locate your e-mails from the last time you helped me out.
      So my sisters Dell C610 latitudes bios is in need of a password.
      I can't remember where I got those extra 4 characters after the 7 character service tag from. I have seen '595B' in earlier posts but I am unsure if that is correct for my model.
      Service tag: 5NLKC11
      Let me know if I need to dig deeper and figure out those extra 4 . . .
      Thanks again in advance Brother!!
      [email protected]
      • xraydelta101
        • 75
        #1578
        try this 9v2onk41 4th is o for orange
        • xraydelta101
          • 75
          #1579
          Originally posted by fredskidoo
          Hello
          [email protected]
          try this based on end of tag-595B
          password is 6fazxu6h
          • fredskidoo
            • Jun 2011
            • 10
            #1580
            Hey Xraydelta101 - many thanks for your response!
            Gave it a shot without success BUT allow me to give some details that Probably will help with figuring out the C610 Latitudes attitude.
            On page 7 (system security) of the BIOS (v. A16) it states:
            "The 'ADMIN' Password' field is locked until the 'Configure Setup' field is enabled."
            So I started with entering the info you supplied in the 'configure Setup' field with no success - then I tried the 'ADMIN Password' field but that (of course) isn't active.
            But then I tried the 'Primary password' field and after entering the supplied info twice successfully that field went from disabled to enabled in a white font rather than the unactive blue fonts. I have since set the 'primary password' field back to disabled.
            I believe if I can get the 'Config Setuo' field to accept a password I should be able to get to the point where I can clear the Admin Password as well. At this point the 'Configure Setup' field says diaabled and when I press the L or R keys it says 'Enter Config Password' with a full row of ******** in the password field unlike earlier when I accessed the Primary Password field which gave me a blank space to enter the password.
            So basically it looks like this:
            **********System security************
            Primary Password: disabled (white font)
            Admin Password: enabled
            Configure Setup: disabled (white font)
            Configure Passwords: enabled
            Let me know if I can reciprocate for your help i.e. paypal, etc. as it is bad enough today that I had to break it to my little Sister that her HD took a dump while I was running a disk imaging backup to try to save it before it Twacked itself to death but now this damn Dell BIOS wont even recognize any drives that I've put in.
            Thanks Again Brother
            BTW: Is there some posting method for giving thanks because if you notice below my Avatar I've accumulated zero 'Thanks' and I'd like to change that.
            Easy - E
            Service Tag: 5NLKC11
            Express service Code: 12310854373
            • smoggy
              • Apr 2009
              • 12772
              #1581
              password 9v2onk41 4th is o for orange
              • smoggy
                • Apr 2009
                • 12772
                #1582
                fredskidoo
                to give thanks : on the bottom right hand corner of a persons post there are 2 tabs Quote and Thanks, clicking on the Thanks button will thank the poster.
                are you using a QWERTY type keyboard
                if you type in the wrong password 3 times does it give a system error number
                • xraydelta101
                  • 75
                  #1583
                  Originally posted by smoggy
                  fredskidoo
                  i havent got a clue mate i will leave this in your expert hands
                  • xraydelta101
                    • 75
                    #1584
                    fredskidoo
                    i do not accept money but if you wish please donate to DK the best forum on the net
                    • fredskidoo
                      • Jun 2011
                      • 10
                      #1585
                      AHHHHHH!!
                      Hey Smoggy
                      Just the Dell standard keyboard (double checked - no caplock on) as far as entering a "wrong" password 3 times I am unclear where I would be entering an incorrect password 3 times. Do you mean at the initial password request point AFTER pressing F2 but BEFORE entering BIOS or on page 7 of the dell's BIOS setup i.e. System Security.
                      Originally the primary password was disabled - when I received the password from D.K. forum it worked to enable and disable the primary password on the system security page BUT was ineffective with what is the real roadblock.....
                      On the system setup page after "primary password' and 'admin password' is the 'configure setup" option. It is set to 'disabled' (meaning it has disabled the making of any changes to the bios)
                      I can select it and press the L key to change it to read "enter config password" which produces 8 ***** in the password field - (Note: 6fazxu6h does not work no does entering an incorrect password 3 times - it just makes a shrill beep every time the password is entered incorrectly.) It has never given me any sort of error number either.
                      So I believe, as it states clearly in the right hand side frame of my Bios, that I need to enable the configure setup before anything will work.
                      Once I correctly enter this password then I can go on to the Administrator's password, which may or may not be the one you have already supplied me with. 6fazxu6h.
                      Is this something you've come across before?
                      Is it possible to obtain the "Configure Setup" password?
                      Regardless - Thanks for taking the time to read my crap!!
                      I would much rather have a conversation real-time or even
                      attach some photos or a walk through video as I feel that I may not be clarifying the problem well enough.
                      What really sucks is my sis bought herself a brand new laptop and it was stolen within a month and so she's back with the CrapTop . . .
                      Easy - E
                      • smoggy
                        • Apr 2009
                        • 12772
                        #1586
                        fredskidoo
                        I have never come across a configure set up password so at a bit of a loss for that
                        normally the Bios master password works for Bios and Admin password unless user has changed the Admin pass
                        some models give a system error number if wrong password is entered 3 times and a password can sometimes be calculated from it.
                        QWERTY keyboard is first 6 keys on top line as there are AZERTY and QWERTZ keyboards plus others
                        • xraydelta101
                          • 75
                          #1587
                          i need summit what fredskidoo's on
                          • fredskidoo
                            • Jun 2011
                            • 10
                            #1588
                            All I can say is DSTCD
                            Thanks for the responses Xraydelta101 & Smoggy
                            . . . and Good 'ol TPB
                            And Thus it was known . . .
                            Easy - E
                            • sockrebel
                              • Feb 2012
                              #1589
                              hello,
                              I have a dell latitude e6220
                              tag = #CBSTWP1-1D3B
                              would appreciate any help in unlocking the BIOS.
                              • indotiger
                                • Feb 2012
                                • 4
                                #1590
                                Originally posted by JustMeAgain
                                wpb65wjm is the pass.
                                Dont forget thanks.
                                Thank you very much. Appreciate your time and help.
