dell latitude d630 admin password ??
  • benorqui
    #451
    need the admin pasword of my dell latitude d630
    my service tag is H3SKTF1
    • egyclick
      • 436
      #452
      hello,
      if the service tag shown on the display is H3SKTF1-595B
      the password is: j1qw32vr
      cheers!
      • stressman49
        • 7
        #453
        need pass for fpqcld1
        • stressman49
          • 7
          #454
          password for dell fpqcld1
          • smoggy
            • Apr 2009
            • 12772
            #455
            no need to double post
            its preferred that your first post should be here Introduce Yourself
            in the meantime if tag ends 595B then pass j4u10pqb (5th is a zero)
            EDIT : sorry but the fourth is l not 1
            • stressman49
              • 7
              #456
              hi smog can you please give me the password for fpqcld1
              • stressman49
                • 7
                #457
                the code you gave me did't work. is their another one thanks
                • vareesh
                  #458
                  help please.
                  Hi guys! need help with "power on password" of a latitude d630.
                  Bios Revision A03 for system 6BDDMD1. thanks!
                  • bechiche
                    • 60
                    #459
                    TRY:
                    4ybw06e7
                    • bechiche
                      • 60
                      #460
                      try:
                      4ybw06e7
                      • vareesh
                        #461
                        Originally posted by bechiche
                        TRY:
                        4ybw06e7
                        hey bechiche. thanks for your help but no dice. password invalid.
                        • smoggy
                          • Apr 2009
                          • 12772
                          #462
                          varish the password by bechiche was not for you
                          providing your tag ends -595B your password bcrug35k
                          • vareesh
                            #463
                            hey smoggy! you are a god. it worked perfectly 100%. thank you for your help. i've been troubling with this for the past month!
                            • smoggy
                              • Apr 2009
                              • 12772
                              #464
                              stressman post all of your service tag xxxxxxx-xxxx
                              remember it is case sensitive
                              EDIT : sorry but in the last code I gave you the fourth should be l (l for lover in lower case)
                              • stressman49
                                • 7
                                #465
                                hi smog still no luck for fpqcld1-595b any other codes thanks
