dell latitude d630 admin password ??
  • smoggy
    • Apr 2009
    • 12772
    #466
    Originally posted by stressman49
    hi smog still no luck for fpqcld1-595b any other codes thanks
    for fpqcld1-595B (not 595b) password = j4ul0pqb
    j for july
    4
    u for us
    l for lover
    0 zero
    p for poppy
    q for queen
    b for bob
    make sure you are entering in proper case settings
    • benorqui
      #467
      Thank you!!!
      Work perfect!!!!!
      • egyclick
        • 436
        #468
        j for july
        4
        u for us
        l for lover
        0 zero
        p for poppy
        q for queen
        b for bob
        The service tag is FPQCLD1-595B they are all uppercase
        and the password for that one is:
        nxlliyja (3rd and 4th characters are 'l' from 'light')
        hope it helped
        cheers!
        • stressman49
          • 7
          #469
          do you have code for harddrive 77PBTIY7T
          • egyclick
            • 436
            #470
            if it's original HDD the password for the complete service tag:
            **77PBTIY7T-595B should be: g8f3i6ef
            or if it's
            7PBTIY7T**-595B password is: 5qocqne0 (only last character is Zero)
            cheers!
            • stressman49
              • 7
              #471
              thanks smog&egyclick for all your help
              • bazzw6
                • 81
                #472
                i thought that only ibm had the secure hardware chip for bios security???
                therefor any other lappy all you have to do is take out the battery and bios battery for a few minutes to reset ...or short accross the bios battery ????
                • terrsimm3
                  • Feb 2011
                  • 5
                  #473
                  I have a Fujitsu drive serial NZ0UT792EPEM that is locked. I have software that can unlock if the Master password is known. How can I get this master password?
                  • egyclick
                    • 436
                    #474
                    just enter 3 wrong passwords and you will see a System disabled message with a number next to it, post here that number and I will help you.
                    cheers!
                    • lingnoi
                      • 84
                      #475
                      I have a Dell D630 with service code: 143-460-242-11
                      Please let me know the password.
                      Thanks.
                      Regards, L
                      • egyclick
                        • 436
                        #476
                        Originally posted by lingnoi
                        Thanks.
                        Regards, L
                        if you read just 3 other post you will see that no one generates passwords from service code... just read!
                        • volk1302
                          • 5
                          #477
                          Hi! Pls, calculate password for DELL610
                          My System Number:25W9291-595B
                          Thanks in advance!
                          • lmsvvavr
                            • Jul 2010
                            • 569
                            #478
                            Thanks in advance!
                            your password should be 5ny2clom
                            Hit Thanks if helped you!
                            Thank You for the help!
                            "A Wise Man can see more from the bottom of a well than a Fool can see from the top of a mountain."
                            http://www.youtube.com/c/LMAutoRepairs
                            • lostincyberspace
                              • 5
                              #479
                              dell 630
                              Can you help with FJL2TF1? Is this an admin password or Bios password? Can I reset Admin from bios screen? Tried pulling both batteries and some software from cd crive but has not worked. Thank you for any response!
                              • barbellrow
                                • 62
                                #480
                                are you just trying to bypass the admin log in screen?
                                I saw a billboard on the way to work this morning that read "Future Events."
                                Well, that's a sign of things to come.
