hi all wondering if anybody can point me in right direction, my problem is when i boot up lappy it goes to we apoligize for inconvenience but windows did not start succesfully i have tried start windows normally then reboots to windows xp page then reboots again tried safe mode,with networking,with command prompt and last known good config same problem i can get in bios set up,he told me he got this error but cant remember what he did to get this far page_fault_in_nonpaged_area is there anything i can try or will i have to reinstall windows any help would be appreciated tx stags
MY XP ON LAPTOP KEEPS REBOOTING
try repairing mbr (memory boot record) you will need your installation disc, link to explain how to.hi all wondering if anybody can point me in right direction, my problem is when i boot up lappy it goes to we apoligize for inconvenience but windows did not start succesfully i have tried start windows normally then reboots to windows xp page then reboots again tried safe mode,with networking,with command prompt and last known good config same problem i can get in bios set up,he told me he got this error but cant remember what he did to get this far page_fault_in_nonpaged_area is there anything i can try or will i have to reinstall windows any help would be appreciated tx stags
XP: Repair or fix master boot record using recovery console | Windows installation | Tech-Recipessigpic -
i suppose you could try it as to wheather its a disc thats tied to one brand of pc or simply an installation disc for xp i do not really know but give it a go.
to add as the pc you are trying to recover is a laptop is there a recovery software built in to it which you should see as the laptop boots and access by pressing a paticular key as it boots.Last edited by dasteph; 20 November, 2009, 00:29.sigpicComment
1. From the desktop right-click on My Computer.
2. Click the Properties option.
3. In the System Properties window click the Advanced tab.
4. In Advanced click the Settings button under Startup and Recovery.
5. In the Startup and Recovery window uncheck the Automatically restart check box.
6. Click Ok.
they this m8any information provided is for educational/experimental purposes only.Comment
go into your bios and check that the following are DISBLED
Shadow cache (also sometimes called: F000, 64k, F Segment, System ROM, Adaptor ROM, C000, C400 etc) just make sure anything SHADOW is disabled.
Virus checking.
VGA pallate snoop.
System Bios Cachable.
Video Bios Cachable.
Try again.
If you still get no joy try disabling L1 and L2 cache (sometimes called external)
Try again.
If you still have no joy, try disabling just about anything not relating to basic Ram and Hard Drive functions.
Try again.
If its still not working then that points to a RAM fault, north bridge fault, video board fault or in rare cases hard drive faults.
If things do work then restart and begin enabling higher features in the bios, one at a time untill it stops to pin the bastard down.He who laughs last thinks slowest.Comment
