Medion 97409 P6625 laptop Stuck on median logo during boot
  • Grover2000
    • 104
    My Median laptop is stuck on the Median logo and if left on long enough, it starts to over heat with the fans kicking.
    Can anyone advise what the fault could be?
    Any help is greatly appreciated
    Grover
  • Master200
    • Mar 2017
    • 28
    Did u try to enter in BIOS to see if the hard drive is recognized?
    Do you have HDD or SSD?
    Nothing good to say?Then just shut up!
    • Grover2000
      • 104
      The laptop will not even give me the option to enter the bios. The laptop has a HDD.
      Grover
      • Master200
        • Mar 2017
        • 28
        When you start the laptop as soon as you push the ON button try pressing F1 or F2 or F12 or Delete. I don't know exactly which one is for your Bios. I had the same problem but then i could enter in bios to see that the HDD was not recognized.
        • Grover2000
          • 104
          I initially tried them but nothing happens. I have just tried these keys again but nothing happens except for a beep sound due to continuous pressing of keyboard key.
          Grover
          • Grover2000
            • 104
            So far...
            I have moved both memory sticks and switched on - fans are still going but blank screen (Red led on front)
            Same fault as above with single memory
            Same fault as above with single memory swapped slots
            I have removed the HD with both memory still in and the still stuck on Median logo with fans going (Initial fault)
            Single memory with HD removed and same fault as above
            All components back as they were and without power lead - results laptop stays on with initial fault then after about 2 mins, self shuts-down
            All components back as they were and with power lead - results laptop stays on with initial fault.
            I have taken the battery off and plug mains in and unfortunately same results (Initial Fault).
            I am going to try and swap out the HD.
