Do i put the File in Registry?
  • tommybuck
    • Aug 2009
    • 48
    A window pops up when i open the cracked file theres a payload file with it but i dont know where to put it
    Heres wat it says '' system.nullreferenceexception : Object
    reference not set to an instance of an object at farmville.form1.checkregistry() ''
    so i try to open the file on windows 7 OS and it comes up with that message the person who sent it to me said it was a full version along with a payload file so where do i put the payload file? as its cracked already just i do not know where to put the payload if you want to check it heres the dl link its farmville extreme manager =P its sad lmao but i aint paying 15 dollaz for it
    RapidShare: 1-CLICK Web hosting - Easy Filehosting
  • tommybuck
    • Aug 2009
    • 48
    anyone? idk whats too doo
    • chroma
      • 1976
      the varaiable located in the object "farmville.form1.checkregistry()" is NULL meaning that the code is asking for a variable and theres not one stored at the location its asking for.
      This is completely down to an error in the code, the coder in this case is an idiot who doesnt know how to check his objects before referencing them in his methods.
      Theres absoloutly no reason a flash based game should be doing anything with your registry, if its attempting to modify registry entries then its more than just a game and id say poses a security threat.
      He who laughs last thinks slowest.
      • ianmac
        • Oct 2008
        • 922
        You can try this one if you like.
        Instructions:
        1. Intall
        2. Copy the file from inside the crack folder into the Farming Extreme Manager Intallation folder, and when asked to over write the old one. choose "yes".
        I.E: C:\Program Files\AutomationLabs\Farming Extreme Manager...
        Tested it on windows XP 32bit.
        Hope this helps
        Ian
        P.S. It's a bit sad if youv'e gotta use this to beat your'e mates...
        • sinbad
          • 15
          so you trying to cheat farmville on facebook then if you are thay dont work lets you do it but when you go back all you bought will have gone same as farm town hacks and bots
          • tommybuck
            • Aug 2009
            • 48
            em does this work on Windows 7? as it is freezing on myne and how do i fix that?
