at system check get this warning,(secondary ide channel no80 conductor cable installed). system health ok, memory testing ok prompted to press f1 to continue, del system set up and so on... so press f1 everything is fine windows loads no prob checked in bios all drives recognised including cd on this ide channel, noprobs in device manager eg dodgy drivers ect. but when turn comp off or restart just get no signal on monitor then black screen, every time i need to reeboot need to remove and replace battery back then defaults loaded in bios checked connections but to no avail even changed ide cable no change....do you think i need to change my ide cable to an 80 pin one , any help would be most welcome.
has anyone come across this prob
Tags: None
cheers nano. wasnt sure if was cable, will get a new battery and try that. tower about 4yrs old so assume batt same, will it just be a case of changing battery or do i need to set up afterwards.Comment
update.changed ide cable that prob solved...changed battery but no different still will not boot after power down , just no signal to monitor and keyboard not lighting, remove and replace battery still same check sum error. can anyone throw some light on this.Comment
hi m8
after all checks you made i will ask you the obvious can you hear fan on power supply if so that rules out dodgy psu .just thought the cheksum error could be indicating faulty memory if not that board is deadComment
