TOSHIBA SATTELITE WONT TURN ON PLZ HELP
  • ginge21
    • 44
    I LOST MY CHARGER FOR MY TOSHIBA LAPTOP I RESENTLY PURCHASED A NEW 1 HOWEVER IT IS PLUGGED IN AND ALL I GET IS THE CHARGING LIGHT JUST FLASHING AND THE LAPTOP WONT TURN ON WHAT CUD BE THE ISSUE THANKS IN ADVANCE
  • krazylegz
    • 2834
    could be incorrect voltage, mine is 19v output for a toshiba satellite pro L350, where as my old satellite was only 15v
    PS3= krazylegz120282
    • ginge21
      • 44
      thanks for the reply but i bought it off ebay and its the correct charger for my exact model of laptop it is a sattelite pro200-13z
      • ruudvandan
        • 1091
        will it run directly from the mains with no battery?
        http://www.facebook.com/BoycottFIFASponsors
        • alker ranger
          • 361
          My toshiba satellite wont start up, it switches on but then says it will start up in 30 secs, counts down but then keeps repeating over and over. I have just bought a new one but need to transfer stuffof the old one, any ideas, cheers
          • ruudvandan
            • 1091
            easiest way would be to take the hard drive out and put in into a usb hard drive caddy, you can then copy and paste it onto your new laptop
            • alker ranger
              • 361
              Thanks for that you make it sound so simple, i will get a mate to do that for me, would like to know if old laptop is fixable be a shame to throw away.
              • ruudvandan
                • 1091
                can you get into BIOS at all? If you can then I would suggest seelecting to boot from CD and try and boot your Windows installation disk on a live CD version of Linux. If so then it is a software problem and a reinstallation of an OS should sort it out.
                If you can't get into BIOS then theres something wrong with BIOS that's preventing the computer from booting. I'd start by taking your BIOS battery out of the motherboard and leaving it overnight so it will reset the BIOS.
                Let me know how you get on.
                • alker ranger
                  • 361
                  Thanks ruud, its all to technical for me, will get a m8 to look at it after crimbo and i'll let you know how it goes. Cheers
                  • jfish
                    • 799
                    did you buy a official Toshiba one or some no name one, as I find with the "better" brands of laptops Tosh, IBM, Compaq the official ones tend to work than the cheap ones.
                    • Reapers
                      • 242
                      we will need the model of the laptop and any other relevant info
                      (model sticker on bottom or corner)
                      manual link.
                      TOSHIBA Satellite P200 - Satellite Pro P200 Series User's Manual Guide
                      might also need to do multiple things to reslove this issue.
                      1.reset bios its on the back it tell how to do it in the manual.
                      2.check the ram usually faulty ram interferes with the boot up setup.
                      3.if non of that works then the battery maybe the problem but it still should still boot from the main power.
                      if its brand new get it replaced power problems/faulty
                      • alker ranger
                        • 361
                        [QUOTE=Reapers;385549]we will need the model of the laptop and any other relevant info
                        manual link.
                        if its brand new get it replaced power problems/faulty[/QUO
                        Model is A100 214 can get bios setup menu but not sure what to do next cheers
