cud any1 tell me why my laptop wont charge it is plugged in but there is a blue flashing light and thats all it wont turn on and i dont know why please help as i need my computer for regular use thanks
the power jack is probably loose so it wont charge the battery and wont run from the mains. the blue flashing light indicaties that power entering is intermittant (because of the loose connection) hence it flahses on when poer reaches it and off when it stops. This is a common fault on laptops and the only way to sort it out is strip it down and resolder the power jack so it has a sweet connection.Comment
Problem coulld be the charger or the battery. Can you borrow a working battery and see if your PC turns on and the battery charges ?Comment
