25 FREE BIOS PASSWORD MASTER for Fujitsu-Siemens 6X4
  • smoggy
    • Apr 2009
    • 12774
    #571
    Originally posted by ufficiotecnico
    Can someone help me?
    I followed the procedure, and I get this code:0222-3687-8121-5221-6062-8642
    Fujitsu s752
    Keyboard: QWERTZ
    for qwerty code 0jh1yuyz first is a zero and you will need to change both y's to z and z to y
    • novcat7
      • Nov 2018
      • 4
      #572
      Originally posted by smoggy
      that's correct
      hexadecimal in any other byte throws up error
      I have no experience with this, only code generator but as first post does it make any difference what 3 wrong codes are inputted
      With the three mentioned passwords it doesn't work, for this model you need to input three different passwords to get a hash. And it is always hex. I still haven't found a solution to this problem. None of my scripts seems to work. And also no modification of any of the scripts. It's quite tricky. Thanks a lot anyway for your effort!!
      • milenial87
        • Nov 2018
        #573
        Originally posted by Talleresmalaga
        Fujitsu stylistic Tablet Reset unlock BIOS password hash código 6x4
        Here you can get your master key, for Fujitsu-Siemens Decimal Digits 6X4
        during the next 2 weeks you can request your free master password, up to 25, 1 per registered member
        as?
        When asked for a password, enter these:
        First password: 3hqgo3
        Second password: jqw534
        Third password: 0qww294e
        You will receive a hash code with 6 blocks, each with four numbers,
        eg 12c4-4321-1234-4321-1234-4321
        [ATTACH=CONFIG]491524[/ATTACH]
        Attach this number to generate your master password
        Be careful, every time you speak the previous codes Hash and master password change
        regards
        Hello.. Would You like to help me please, my hash code is 0281-0619-0146-1157-1491-2066
        Thanks a lot..
        • smoggy
          • Apr 2009
          • 12774
          #574
          Thanks a lot..
          try 47jpg4u3
          • milenial87
            • Nov 2018
            #575
            try 47jpg4u3
            Oh Thank You.. It's work
            • Svanteboat
              • Nov 2018
              #576
              Hi can you help me generate my bios password?? code is 0270-0798-2120-1162-9161-2066
              • smoggy
                • Apr 2009
                • 12774
                #577
                for qwerty keyboad try 00zhgqar first 2 are zero's
                • Svanteboat
                  • Nov 2018
                  #578
                  Thanks its works
                  • lukasamd
                    • Nov 2018
                    Please help with Fujitsu S752 (QWERTZ keyboard layout)
                    0222-4046-2061-3853-6101-1778
                    • holyhamid
                      • Nov 2018
                      as?
                      regards
                      Hi There. I have a locked Fujitsu UH552.
                      Hash code is: 0F17-3922-6154-4732-0610-3811
                      Please help me with Master Password.
                      Thank you.
                      • smoggy
                        • Apr 2009
                        • 12774
                        #581
                        Thank you.
                        for qwerty keyboard try cjtoh0ah sixth is a zero
                        • rovip
                          • Nov 2018
                          #582
                          hi
                          need some help on fujitsu celsius H760
                          code is 029A-0651-0515-5857-4332-8418
                          • smoggy
                            • Apr 2009
                            • 12774
                            #583
                            Originally posted by rovip
                            hi
                            try db7dmrmv
                            • rovip
                              • Nov 2018
                              #584
                              try db7dmrmv
                              Hi,
                              the code db7dmrmv is false :-(
                              Do you have another?
                              • laughms
                                • Nov 2018
                                Hi, could you please help me out? I have a Fujitsu Laptop.
                                Code: 02B1-3790-2102-5919-3344-4674
                                Thank you very much!
