Can I run XP on an external hard drive
  • PETERG
    • 203
    I have just upgraded to 7 PRO, hoping to use XP MODE, I have since found out my laptop does not support virtualization. Can I set up XP on an external HDD, create an option to boot from the ext HDD via usb, press f12 at start up & select boot from usb device?
    If so how, idiot proof instructins please.
  • aftermath
    • 4345
    Best thing i can think of is to Partition your HDD on your Laptop.
    Install XP on first partition
    Install Win7 on 2nd Partition, during installation it asks if you want multiboot.
    Thats how i did it..
    • PETERG
      • 203
      Cheers M8,
      Dont suppose you could point in to very simple instructions how to do it?
      • aftermath
        • 4345
        look here
        Dual Boot Windows 7 with XP/Vista in three easy steps - TechSpot
        or here
        How to Dual Boot Windows 7 with XP or Vista - windows 7 - Lifehacker
        How to dual boot Windows XP and Windows 7 (XP installed first)
        • PETERG
          • 203
          Would you happen to know if I can fit a second hard drive into my lap top, or would I have to install a larger hard drive. does available space prevent a second HDD being fitted?
          Toshiba Sattelite Pro P300
          Currently has 120Gb & upgrade to 2Gb ram.
          • dasteph
            • 1293
            i would not think there is room to fit a second hd easiest solution us to go for a bigger hd.
            • thanassis
              • Sep 2009
              • 22
              one solution is to buy a bigger hard disk (WD 320GB sata 2.5'' costs 46euros in my country)
              or make 2 partitions of 60GB on your current disk and install then windows xp and 7 in each partition
              you could use the external hard drive, but the problem is that windows don't have any choice for the disk that boot manager will be installed and maybe it will be installed on the systems disks!!! to avoid that you can remove the laptop disk and install win xp to external!!
