problem getting printer to connect
  • benjdebo
    • 46
    hi i cant get my hp all in one printer to connect to my laptop,i have downloaded the recomended drivers/software from hp web site,but after i set it up it says your device is now ready to use,but at the top it says dissconected,ive removed cable and replaced it still have problem,im running windows7, printer is hp deskjet f2480 laptop is acer aspire 5542,thanks.
  • dasteph
    • 1293
    in control panel/devices and printers is it set as the default printer.
    • domacihren
      I had the same problem (among others). I had my Hp digital imaging monitor closed. So I opend this "monitor" and restarted my computer. And that is it.
      • benjdebo
        • 46
        yes it is set as defauli printer,still cant get it to work ?
        • benjdebo
          • 46
          i have my hp imaging monitor open still cant get it to work ?
          • bigfella
            • 879
            sorry dont mean to hijack ur thread but i ve got the same problem with a lexmark...wont connect ..says offline
            • dasteph
              • 1293
              have you tried using all the usb sockets on your pc, also plugged in any other peripheral just to make sure the connection on pc is ok.
              if having checked the usb ports and still will not work uninstall it and install manually by going into cotrol panel panel and using the add a printer in the printer and devices.
              • bigfella
                • 879
                thanks for the reply ...i think some of her usb ports are a lil unpredictable she was havin trouble with a wireless dongle bein recognised as well
                • BawHeid
                  If you are experiencing problems with connectivity you should try going to HP website or you could uninstall and reinstall drivers for printer, switch off PC - connect printer then switch back on and hopefully the PC will pick up printer.
                  • shedder101
                    • Aug 2009
                    • 63
                    you need to get the updated drivers for the root hub
                    this will be found as a chipset driver update on the motherboard's mfg website
                    install that then re boot and the usb should start working normally
                    Love Your Shed
                    • Reapers
                      • 242
                      Setup Guide
                      User Manual
                      if you need adobe reader which allows to read the manuals here is the link its free.
                      Adobe - Adobe Reader download - All versions
                      depending on which operating system you have you might need to update drivers.
                      (Printer Drivers)
                      windows xp 32 bit
                      http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=uk〈=en&product =3811337
                      windows xp 64 bit
                      http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?os=2030&softwareitem=oj-79942-1&lc=en&dlc=en&cc=uk〈=en&product=3811337
                      Windows vista 32 bit
                      http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=uk〈=en&produc t=3811337
                      Windows Vista 64 bit
                      http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2100&lc=en&dlc=en&cc=uk〈=en&produc t=3811337
                      Windows 7 32 bit
                      http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=4062&lc=en&dlc=en&cc=uk〈=en&produc t=3811337
                      Windows 7 64 bit
                      http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=4063&lc=en&dlc=en&cc=uk〈=en&produc t=3811337
                      Service & Support
                      Acer Aspire 5542 support go on notebook then aspire then scroll down to 5542
                      then pick your operating system and download your drivers for your laptop
                      hope it helps : )
                      • caveman_nige
                        • Feb 2008
                        • 4920
                        i don't know why people buy HP printers... the software is so shite, has been for years.. best place for it is in the bin,,, if its new get a refund and buy a Canon printer...
                        • mickyboy
                          • 524
                          try uninstalling the printer software n reinstall ,and yip cm is spot on hp = pants
                            had my hp all in 1 3 years now not a bit of bother with it, and i can refill me cartridges
