Increase Hard Drive Speeds in XP Win XP Pro
  • biffo1
    • 420
    Simple Tweaking and also works with Windows 2003...
    NOTE: I only recommend doing this if you have 256mb of RAM or higher.
    STEP 1: Start > Run > then type SYSEDIT.EXE
    STEP 2: Expand the system.ini file window.
    STEP 3: Scroll down almost to the end of the file till you find a line called [386enh]
    STEP 4: Press Enter to make one blank line, and in that line type
    Irq14=4096
    NOTE: The above info for the new line is CASE SENSITIVE
    STEP 6: Select File > Save
    STEP 7: Close SYSEDIT and reboot your computer
    [CENTERsigpic[/CENTER]
  • aftermath
    • 4345
    Works in Vista as well, just i had to edit that line in Safe Mode.
